Long time no posting, I have been checking in from time to time though.
My bike has been sitting for a while now and I decided to get it back on the road, starting with the brakes.
I have been trying to get my rear MC bled out for days now and am totally frustrated. I even went out and bought a mity-vac to help. I rebuilt the MC and the caliper and made sure all was clean, new K&L kit in the MC. With my bench setup, I can stick the hose attached to the caliper into a jar of fluid and it draws fine. I connect to the MC (Not sure if I was fully bled on it) and nothing! I am pulling a solid 22inches of vacuum and it is not drawing fluid
I did have it drawing from the MC one time, and when I pushed on the pump/ piston, I lost the draw. I pulled the hose from the MC and tried to bench bleed it, but it doesn't seem to be working.
I filled the MC and poured fluid into the hole where the banjo goes. I try and pump up the pressure and nothing is really happening. Am I pumping to fast? How much stroke does the piston need to build pressure? I thought I had it at one point as I had pad pressure on my blocking board, but when I put it back on the bike-nothing
I have read several threads, but nothing popped out about how much stroke and if it is possible to blow the prime by pushing the piston in too far.
The front was a pain, but nothing like this.
HELP ME PLEASE BEFORE I LOSE MY MIND
I would put it back on the bike personally, and still follow the tips I gave you about filling the caliper as much as possible and checking flow from the MC through the hose and not over compressing the pedal (only 75%)... I completely disassembled my rear MC last year and had no problem putting it back together and getting it to work... did you make sure all the internals were put back the way they came off?
