whats up all! i pulled and cleaned the carbs on my 81 Special. all throttle postitions seem good, no hesitation, seems like all carb circuts good except when 1st started with choke. i get popping thru the carbs a little only when cold. i try to pull the choke off asap, then its better untill it gets warm, then great. carbs are all stock 110 mains 42.5 pilots, needles stock. i have a Kirker 4/1, stock air box, i initally set idle mix screws back to stock setting, 2.5 turns out, then reset .25 richer to see what effect it had. better? not sure but i think so. its not so black and white, ya know what i mean. isnt the popping from a lean condition? how far should/can i turn out the mix screws? im not totally clear on it. thanx
