I am restoring an 80 mns and am in the process of hooking up the fuel lines from the petcocks to the octy and want to make sure I get them correct as they were removed I have looked a posts for some help but would like some in put as to where the lines run. two lines which come from the octy have t's which I think goes to the carbs and also hooks to one side of the petcock. one line feeds two carbs,does other line from the petcocks run into the other open inlets on the octy? all four lines have in line filters does this sound correct does any one have any pictures of the setup also in which postion should the petcocks be in when I go to start this up, carbs were taken apart and cleaned and reassembled
thanks
thanks
