I finished the autopsy on the XS750 final drive this afternoon: the large right-side ring gear carrier bearing failed and the ring and pinion gears are worn and wiped out.
After the final drive autopsy I took apart the original XS1100 final drive that was on my bike when I bought it so I could compare the two final drives. I made a Youtube video of the bad and good final drive side bearings and of course I took a lot of pictures.
On to the video and pictures! Click any image and it will load the large version:-
A bad XS750 final drive side bearing and a good XS1100 side bearing
![](http://i2.ytimg.com/vi/AvSocoSFMjo/2.jpg)
XS750 and XS1100 final drives.
750 on the left, 1100 on the right. The 750 final drive ring gear is not as sturdy as the XS1100 ring gear and it does not have an axle tube support.
![](http://farm7.static.flickr.com/6017/5963351704_909664cf28_d.jpg)
XS750 and XS1100 ring and pinion gears.
The 750 is on the left, 1100 on the right. The teeth on the 750 ring and piniongears are a lot thinner than the teeth on the XS1100 gears.
![](http://farm7.static.flickr.com/6136/5962794369_c463e435eb_d.jpg)
XS750 and XS1100 ring gear. The 750 ring gear is much smaller and thinner than the XS1100 ring gear.
![](http://farm7.static.flickr.com/6146/5962792781_7104d98e46_d.jpg)
The inner side of the XS1100 ring gear.
The ring gear and its inner bearing hub are both larger than an XS750 ring gear.
The wear pattern on the inner hub race shows that it is still in good condiftion.
![](http://farm7.static.flickr.com/6008/5963347412_b27046555f_d.jpg)
The inner side of the XS750 ring gear.
The ring gear and its inner bearing hub are both smaller than an XS1100 ring gear.
The wear pattern and score marks on the inner hub race show that it is worn out and has begun to fail.
![](http://farm7.static.flickr.com/6131/5963346096_2fd907ab86_d.jpg)
Gear tooth face wear on the drive side of the XS750 ring gear.
The contact pattern shows smearing and heavy wear with some chattering.
The chattering was caused by a failed side carrier bearing.
The smearing and heavy wear is caused by the ring gear flexing away from the pinion gear under loads it was not designed to handle.
![](http://farm7.static.flickr.com/6142/5962788571_7ff49484c2_d.jpg)
Gear tooth face wear on the drive side of the XS1100 ring gear.
The contact pattern shows almost no wear and normal contact between the ring and pinion gears.
![](http://farm7.static.flickr.com/6129/5962787131_27603987c1_d.jpg)
Gear tooth face wear on the coast side of the XS1100 ring gear.
![](http://farm7.static.flickr.com/6125/5962785733_7a066cc672_d.jpg)
Gear tooth face wear on the coast side of the XS750 ring gear.
![](http://farm7.static.flickr.com/6002/5963340810_6a347e7937_d.jpg)
XS1100 pinion shaft, inner pinion bearing race and the pinion gear.
The XS1100 pinion shaft has teeth to hold the inner pinion bearing race.
![](http://farm7.static.flickr.com/6142/5962783101_b50343b3ab_d.jpg)
XS750 pinion shaft, inner pinion bearing race and the pinion gear.
The XS750 pinion shaft has no teeth to hold the inner pinion bearing race.
![](http://farm7.static.flickr.com/6134/5962781755_8dc2f85b0b_d.jpg)
XS750 final drive housing.
Apparently the gear oil overheated and blackened the inside of the housing.
![](http://farm7.static.flickr.com/6001/5962780413_772f588e2b_d.jpg)
XS1100 final drive housing.
The final drive has not been overheated and the inside of the housing and the gear oil are normal.
![](http://farm7.static.flickr.com/6122/5963335064_7f60ce0805_d.jpg)
