compression test-above spec?
  • EricHa
    • Mar 2009
    • 201
    • IL
    I recently picked up a XS1100SF from niterider and just did a compression test using a Lisle tester. The bike shows 8200 miles and has all original equipment, though it's fairly rough, nickname Rusty.
    I removed the plugs, and held the throttle wide open and spun the starter until compression ceased to rise (4-5 seconds). Numbers were 173, 173, 165, and 174psi. Engine cold, 600 ft. altitutde. Spec says a max of 156psi. I'm thinking that the bores are in good shape, but why such high numbers?
    Thanks to all for such a great forum!
    Eric
    1979 Yamaha XS1100SF (gone)
    Airbox w/K&N element
    Jardine 4 into 1
    145 mains, 45 pilots
    1996 Ducati 900SS CR
    1977 Kawasaki KZ900-A5
    1975 Honda CB550K
    • 8862
    Might be carboned up?
      • 9980
      8200 or 82000?
      • EricHa
        • Mar 2009
        • 201
        • IL
        8200, and yes, it could quite possibly be full of carbon. Plugs looked fairly dark with a little tan. What's the best way to clean it out? Is it time to hit the search?
        Jardine 4 into 1
        1975 Honda CB550K
          • 9980
          That engine ain't even broke in yet. Ride it a while and recheck.
          • EricHa
            • Mar 2009
            • 201
            • IL
            She's running pretty rough down low, missing on at least one hole at startup, but cleans up somewhat when warm,, and scoots after 3 grand. Carbs really need to be gone through. OEM mufflers are rusted out and I picked up a Jardine 4 into 1 so it's time I guess. Thinking 142.5 mains and one bigger on the pilot jet?
            Jardine 4 into 1
            1975 Honda CB550K
              • 9980
              Try it stock jets first. It shouldn't make a differrence unless you want to go 130MPH.
              The early engines don't have much oomf under 3 grand anyway. You just gotta keep the RPMs up when riding.
              Clean up the carbs and give it a try.
                ...I removed the plugs, and held the throttle wide open and spun the starter until compression ceased to rise (4-5 seconds). Numbers were 173, 173, 165, and 174psi. Engine cold, 600 ft. altitutde. Spec says a max of 156psi. I'm thinking that the bores are in good shape, but why such high numbers?...
                I don't think those are high IMO... I suspect that the 'spec' numbers are low (to give Yamaha some 'cheat' room on warranty work?), as the only ones I've run into with numbers in the 140-150 range (or less) had mechanical issues or high miles. The SG I just finished putting together checked at 180-190 (plugs out, carbs off) and runs just fine so far. I've got a '79 motor that ran between 190 and 205 (same test procedure). Neither have more than normal amounts of carbon from what I can see.
                • TADracer
                  • 1417
                  • Kenner, Louisiana USA
                  I agree with Steve. My last comp check in May was , 172, 172, 165, 168. But you should check that with the motor at operating temp and WOT.
                  On the jet thing, I would make that the last thing you try to clear up sooty plugs. Its a mistake, IMHO, that many people get into because before you start changing jetting you really need a good, established baseline to tune from otherwise you will be doing alot of head scratching. Try to get the thing running close to factory specs before you start changing up jetting and then ride it awhile to feel it out and see if it gets back on its legs before you dive into tuning changes. Just my $.02
                  Mike Giroir
                  79 XS-1100 Special
                  • EricHa
                    • Mar 2009
                    • 201
                    • IL
                    Then I'm going to assume my numbers are normal. I did think that Yamaha's 142-156psi was fairly low.
                    I'll try the header with stock jetting as a base line after I clean the carbs. Thanks for the advise.
                    Jardine 4 into 1
                    1975 Honda CB550K
                    • psycoreefer
                      • Feb 2008
                      • 1557
                      • Minden, NV
                      I'll just jump in and 3rd the oppinion that the published numbers are low, I just put SWMBO's engine back together and with a light hone and old rings I was at 130-ish across, after riding for a week that jumped up to 180+ on all 4. I cleaned out the chambers while I had it apart and I promise that it didn't build up that much carbon in a week.
                      1979 xs1100 Special -
                      My Bike:
                      [link is broken]
