oil stick?
  • dogyear58
    • Aug 2007
    • 45
    • cold country minnesota
    oil stick?
    Hi there XS gang.............
    What I was thinking about was the shaft & rear drive oil stick level.......
    where can I get one or find the oil level from the top?
    Thanks...........from the dog....
    81XS1100sp full dresser.
    79XS1100sp rat bike.
  • petejw
    • 2269
    • sydney australia
    here u go dog
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • cruiser
      • Jul 2004
      • 393
      • Winona, Minnesota
      They are still available from Yamaha also for around $6
      XJ1100 Ruby Red
      XS1100LH "Midnight"
      1972 MGB Roadster "sold"
      • Prothec
        • Jul 2007
        • 587
        • Fort Myers, FL
        I had an old plastic coffee can lid laying around and used that to cut out a few with the template. Works great and will last until I lose them, but I keep forgetting to notch them or punch some holes in it because permanent marker doesn't last very long
        Website/Blog
        • CatatonicBug
          • 6117
          • Clinton, UT
          I did the same thing, but used a piece of lexan I had. The notch is definitely the way to go, as it doesn't wash off in the oil.
          If you're interested, on my website (linked below) you can download a sheet that has 10 of them printed on it, for one-time use.
          • Azoroth
            • May 2011
            • 82
            • Idaho Falls, ID
            I took some cold roll and welded a nut on the end. Found the measurements online. I then stuck them in my lathe and put notches in them and made them the correct size and everything.
            1980 Yamaha XS1100SG
            1984 Honda VF700F Interceptor
            1967 Yamaha YL2C
              I went to my Yamaha dealer and order me up a new dipstick and then picked it up about a week later. Cost me less than $10 (less than $8 I think), now it sits in my right saddlebag with the rest of my tools (that saddlebag is my toolkit, the other side is where I keep water bottles and bungee cords and such, the trunk is for food and groceries.
