Gasket material ?
  • oldnortonrider
    • 448
    Gasket material ?
    I've made some "adapters" to be able to attach my XS1100 fuel
    petcocks onto the bottom of a Kawasaki Concours 7 & half gallon
    gas tank. (??) Does anybody know of a gasket material or
    a "squeeze gasket sealant", that would be impervious to fuel>that I can locate, to make my own
    gasket(s) for this project?
    (I think I saw that information somewhere within the last year, maybe on this site, or some link. Can't believe I didn't save it, or store it.)
    JCarltonRiggs
  • wildbill
    • Feb 2003
    • 346
    • western NC
    It depends on how much gap you have.Flex and so forth,if the gap isn`t much you could try some Permatex 2 form a gasket sealant{non-hardening pliable sealant}.The stuff can be found at auto parts stores.I used it to seal around the petcocks on my bike,78E, and it works real good.Hope this helps.
    Bill Harvell
    • oldnortonrider
      • 448
      Thanks Wildbill .........; when you used the "Permatex 2" sealant> were you also using the O-ring type seals on the
      petcocks?
      JCarltonRiggs
      • wildbill
        • Feb 2003
        • 346
        • western NC
        petcocks?
        On my bike I left the O-ring type seals on,then used the sealant with it.Hope this helps.
        Bill Harvell
        • CMA1
          • Jul 2003
          • 114
          • Ontario, Canada
          "HYLOMAR" is the stuff to use on fuel related items like you mention. It gets 'thick' enough to fill in small dents and imperfections but stays pliable and does not 'dry' out.
          It is unaffected by fuels. Coat all surfaces (ie. both sides of gasket, tank surface, and petcock mating surfaces.) it works !!
          '79 Special
            Re: Gasket material ?
            Why would you need to swap petcocks? Were the Kawi's petcocks bad? They all do the same thing, allow fuel flow to the carbs. Are you using the 'Octopus' in the fuel system? You must get some hellacious range with a 7.5 gal tank! My 80 SG only gets 100-110 miles per tank. I wish I could get that kind of range. How does it look? Did you have to modify anything?
            • oldnortonrider
              • 448
              CMA1 > thanks for the lead for "Hylomar" .
              I checked/searched around on the web thru Google>lotsa testimonials about Hylomar . Some were "forming" a gasket that
              could be reused.
              JCarltonRiggs
              • oldnortonrider
                • 448
                John > here's the "story" on the Concours tank > back in
                the 80s, when I had lotsa money, one of the motorcycles that I
                bought was a new 1986 Concours. After I'd had it about 6 months, my 16 year old son, missed a corner, blammed into a
                guardrail. He was lucky, he'd slowed down to about 20mph, before he whammed into it. Threw him over the guardrail into a
                "soft" sagegrass field. I don't think he even got a bruise out of
                the deal. Although he was stiff and sore for a few days.
                Demolished the fairing on the Concours, and had a small
                knee-dent on the tank. I replaced everything; saved the tank all
                these years with the "knee-dent" > not really knowing, for most of those years, what I'd end up doing with it. Until a few years ago, I started thinking about how "good" it would look on my '81 XS11Special, that I've developed a good bit of admiration and respect for since I've been riding it. Got it in '95. Of course, the
                original tank lid, petcock and fuel indicator apparatus, all , went
                on the new "replacement" tank for the wrecked Kawasaki. I had
                extra XS petcocks, that I had rebuilt a few years ago, not being
                used; they'll be used now. I did "reshape" the bottom part of
                the underneath section of the Concours tank, where the two doubleloop parts of the top part of the XS frame lets the tank
                sit down on. Did this with a Benzomatic propane torch and a hammer. Before I did "the hammer treatment", it wuz sittin' up
                too high. Just enough room now for "one" petcock. Haven't got it
                together, yet. When it is finished, I'll either post a picture, or send
                you a picture. May do both.
                ......... and, yes, I'm a firm believer in having the "vacuum
                piston diaphragm" setup (the "octopus"). Can't let the "fuel system part(s)" of
                this fine motorcycle, set, much length of time, not having "Sta-bil" in the gas, though.
                JCarltonRiggs
                • foxjohnc
                  • Sep 2003
                  • 90
                  What kind of Norton do you ride? I have a '75 MKIII 850 Commando Roadster, how about you?
                  • oldnortonrider
                    • 448
                    foxjohnc > has been "a while" since I had been on a
                    Norton. I had a 1955 "Dominator '99' ", that I acquired in 1957.
                    Tweaked it and hot rodded it from that time, until 1961.
                    Put between 60-70,000 miles on it, in that period.
                    (Several overhauls and rebuilds.) It was famous
                    on the highways and streets of NW Arkansas, in that time.
                    You might want to check >this "Norton riders' site" >
                    I've never been to any of their meets; but I'm a close acquaintance of one of their most "dedicated"> lives in Siloam Springs,AR. He's given me a buncha pictures of some of the
                    machines, that have been ridden and hauled to their "Lake 'O the
                    Pines" yearly October meet. Those guys are serious motorheads.
                    JCarltonRiggs
                    • wildbill
                      • Feb 2003
                      • 346
                      • western NC
                      Have you got your tank fixed yet?Did you use the Yamaha petcocks or the one that came on the tank your useing?Hope it worked out for you,would like to hear{or find out}how it worked out.
                      Bill Harvell
                      • oldnortonrider
                        • 448
                        Not there yet>;but I'm gettin' there......
                        Waitin' on lid/tank cap, & various "gaskets"......., to get here> ordered from "Ron Ayers" . .......And, had decided to try the "Hylomar"; it's ordered>hasn't got here yet.
                        I'm going to start, in the beginning use of this tank, when installed> with "one" petcock. Petcock that I'm using>to start with (unless I change my mind, before it gits on the machine)> is a petcock off of an XS11 "Standard" tank. I have 2 of them; I might put them both on ..........., eventually (maybe, maybe).
                        I'll keep you posted, on it..........
                        JCarltonRiggs
                        • CMA1
                          • Jul 2003
                          • 114
                          • Ontario, Canada
                          Good choice with the Hylomar.
                          If you haven't used it before.... I have one suggestion.
                          While applying it to 'all' sufaces, work QUICKLY !!! The Hylomar, while never hardening, does 'thicken'. It is easiest to work with as soon as it comes out of the tube and starts to thicken in about 45 seconds (making it less spreadable). Once spread on all mating sufaces, align the parts and tighten the hold-down scrws evenly and tighten. Let the Hylomar set-up for about an hour.
                          I like it, it's good stuff.
                          Larry
                          '79 Special
                          • oldnortonrider
                            • 448
                            CMA1 > thanks for the "quick work" tip.
                            A motorhead-friend of mine, had me order an extra tube; he wanted to have it, also, after checking some of the web info on it.
                            JCarltonRiggs
                            • oldnortonrider
                              • 448
                              Hylomar
                              The Hylomar works well; have had the petcock(s) on for about 3 weeks with gas in the tank. No leaking anywhere. Of course I had a couple gallons of gas in the tank, for a couple days, to give it a chance to leak, before I did mount the tank and hook it up. Got the lid with key tumbler and key(s) from Ron Ayers Motorsports, No. Carolina. I was able to attach both petcocks from an XS11 Standard tank, and do have both fuel lines interconnected down by the carburetors.
                              The "real convincer" re: the Hylomar was: in the process of remodeling the bottom of the tank with torch and hammer, to sit down on the frame better (did this about a year ago) > I got too close to the "2 screw-hole" petcock hole with my hammer; and it became "not a perfectly flush>flat fit" anymore. (The surface that would mate up to bottom of petcock). I wuz real unhappy about having done that; but did nothing to alter, or try to work it "back, perfectly flush",..........thinking maybe, just maybe, the boltdown of the petcock would pull it to a "seal". I don't think it would have, without the Hylomar.
                              .....Ahhhhhhhhhhhhhhhhhh..............mechanical art. It wuz almost this good, in the 50s .
                              JCarltonRiggs
