Cutoff Switch
  • Barnfresh
    • Mar 2009
    • 160
    • Abilene, TX
    Cutoff Switch
    The emergency shutoff switch on the throttle handlebar assembly has spent a large portion of its life outside in the rain. It was stuck in the ON position but would not move to STOP. I removed the switch and found it full of rust with the springs frozen - and sure enough the plastic is cracked by the detent ball. I cleaned it up and tried to put it back together but now nothing with the starter button. Is this switch available anywhere? Anybody have a work-around?
    When the horse is dead, dismount.
    Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
    For the time being just hook the two red wires together and your bike will start and run.
    I believe Mikes XS has the parts to rebuild that, also, they are fairly readily available on ebay as well.
      • 2117
      I will look as i might have a new housing that i don't need.
        I have a spare laying around in the garage I know. The starter button is easy and cheap to get, about $5, If the emergency switch is working.
        • Barnfresh
          • Mar 2009
          • 160
          • Abilene, TX
          Found one... Thanks guys.. I need this working before state safety inspection. Not sure if they do. but they should check...
