Number 4 cylinder not firing
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    Hey Guys
    I have a SF that runs bad. Number 4 cylinder has black powdery carbon and the other three are fine. Thinking bad coil or plug wire. Can one sie of the 1 4 coil go bad?
    THX Jerry
    Keep the shiny side up
    1979 XS1100SF
    Mac 4-1
    Drilled airbox Uni filter
    Vmax bars
    Virago 1" shorter shocks
    30K miles
    http://i1228.photobucket.com/albums/...429_135845.jpg
    1981XS1100SH
    '80 G Forks and Triple Tree
    '80 G tank
    Mac Turnouts
    Virago 1" shorter rear shocks
    SH Headlight
    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
    61 Wife
    83 Son
    86 Son
    89 Daughter
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    Originally posted by tweeleft
    Hey Guys
    THX Jerry
    Black powdery carbon doesn't sound like a problem with the spark, but you can check the spark easily by taking the plugs out and with them laying against the head verify that you have good spark on 4. You can also swap 1 and 4 wires around to eliminate spark, but make sure to change plugs at the same time as the plugs could be the problem, so put new plugs in, but I would if getting a problem on only one cylinder suspect a carb issue rather than spark which would tend towards a pair of cylinders rather than one, it just sounds like it's running rich.
      • 8962
      Unscrew the cap from the wire at the plug end and trim 1/4" off and screw back on. It can corrode up in there.
        Check your plug and do what Phil said and make certain you have spark. You might swap plugs between #4 and another cylinder and see if the problem follows the plug.
        Have you checked compression?
        Black soot indicates too much fuel or the fuel isn't being burt properly.
        • petejw
          • 2269
          • sydney australia
          after checking the ignition as the others have stated,
          might not hurt to check the mixture screw for a broken tip on that carb,
          it wouldnt make it run rich but it would make the cylinder misfire. jat
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • tweeleft
            • May 2009
            • 110
            • Bend Oregon
            thx guys I'll let you know
            1979 XS1100SF
            Mac 4-1
            Vmax bars
            30K miles
            1981XS1100SH
            '80 G tank
            Mac Turnouts
            SH Headlight
            61 Wife
            83 Son
            86 Son
            89 Daughter
            • tweeleft
              • May 2009
              • 110
              • Bend Oregon
              Found #4 plug cap to have 9 omns not 5. ordered new caps and wires. going to check pickup coils and more today
              1979 XS1100SF
              Mac 4-1
              Vmax bars
              30K miles
              1981XS1100SH
              '80 G tank
              Mac Turnouts
              SH Headlight
              61 Wife
              83 Son
              86 Son
              89 Daughter
              • cywelchjr
                • 4450
                • Sacramento, CA
                Unless you have aftermarket coils, the wires are not replaceable without surgery to the coils, and there is a small if non-zero chance of damaging your coils in the process. So unless you KNOW the wires are shot, it's not recommended to try and replace them until you have fixed any other issues first. At least IMHO.
                • tweeleft
                  • May 2009
                  • 110
                  • Bend Oregon
                  Coils test out ok. Cleaned plug caps and regapped plugs. Runs better but haven't ridden and check plugs after ride. will adjust idle mix screws after
                  1979 XS1100SF
                  Mac 4-1
                  Vmax bars
                  30K miles
                  1981XS1100SH
                  '80 G tank
                  Mac Turnouts
                  SH Headlight
                  61 Wife
                  83 Son
                  86 Son
                  89 Daughter
