i apologize for the crappy sound but something still doesnt sound right.....
video of my bike
Tags: None
Sounds like your running on half the cylinders. Check the headers after riding it a few miles or idling for a few minutes and see which ones are hot. I spray water on them to listen for the sizzle.Life is what happens while your planning everything else!
78 XS750 -
sounds like mine..lol.. but mine run on all 4 (sorry left hand.....lol) but di u got the vacume advance hooked up right somtimes that make that ticking sound under idle and goes away under a load.... if that is what your worryed about_____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
1980 gs1000g "stock"
2008 jmstar 150cc Chinese scooter ( wife's bike)Comment
i done the water on the header and cylinders 3 and 4 are screaming hot but 1 and 2 are much coolerComment
Check the fuel supply to those two. Do you have a kinked fuel line? Do you have an in-line filter that may be plugged? If fuel level in the tank is pretty low, try putting the petcock on prime or reserve.Life is what happens while your planning everything else!
78 XS750Comment
the lines are ok and so are my filters and the bike has a half tank of fuel it just really baffles me.Comment
jat,
have u synced the carbs?
one side of the carbs could be getting more fuel than the other side.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Not knowing the condition of the tank when you started, did you pull the petcocks out and check the filters? Have you verified good fuel flow form the petcocks?
1 and 2 are fed from one fuel source, and the way it was running sounds like fuel starvation. So I am focusing on the fuel source to the carbs.Life is what happens while your planning everything else!
78 XS750Comment
