Let me clarify that a bit (I know what you're trying to say Cy, but it's a bit confusing)...
Your RLU (reserve lighting unit) looks for a burned-out headlight, either high or low beam. If the high beam burns out, it automatically switches to low beam and turns on the 'headlight' light; note that if the handlebar switch is on 'high', the 'high beam' light should be lit also. If low beam burns out, it will switch to the high beam, but reduce power to the light so you don't blind oncoming traffic. Again, the 'headlight' light will come on (but not the 'high beam').
Now, if the PO got the wires to the high/low beams switched in the bucket and the 'high' filament is out, when you turn on 'high', that's actually the low beam. When you switch to low, it reduces power (thinking it's the high beam out), making the light dimmer. At this point, the 'headlight' light should come on, but if it's burned out or not hooked up, you won't know but will have exactly these symtoms. So check both the headlight and the 'headlight' indicator bulb...
