Maiden Voyage
  • Barnfresh
    • Mar 2009
    • 160
    • Abilene, TX
    Maiden Voyage
    Maiden Voyage a success! Well, kind of. Started running on two cyl - but I knew to put petcocks on Prime - and started running ok. (it pays to read stuff here!) - then narrowed it down to right side... Also, neutral light stays on even when in gear... Where might the light switch be? Book shows it inside clutch case?
    When the horse is dead, dismount.
    Bagapotomus - '80G Attempted Rescue, '78 Engine, Vetter Bags and Trunk.
    Neutral switch is on the bottom of the motor near the shifter. A wire from the ignition pickup coil harness runs to it. Don't take the switch out unless you tilt the bike to the right somehow, oil will leak out.
