Broken idle mixture screw
  • WDB_xs1100s
    • Jun 2011
    • 26
    • Ashland, Kentucky
    ok so i finaly figured out wht my bike was running really bad. i backed the idle mixture screws out and 1 and 4 didnt have a tip on it. i done further inspection and sure enough they were broke i have tried the methods in the tech tip section and no luck they are REALLY stuck in there i have no idea hot to get them out, i could feel the tip of it on the inside of the carb by the butterfly...i hope i dont have to replace those 2 carbs. anyhelp would be grealty appretiated
  • forexbob
    • Aug 2010
    • 109
    • Calgary
    You're lucky if you can feel the tip of the needle sticking out. I think it's easier this way. I was able to do two carbs using the "internal press" method that I think you're referring to. I soaked and re-soaked and re-soaked the needles with Sea Foam Deep Creep over a period of at least a week. Once you get the needle to actually move flush with the chamber wall, it will take just a little pit of prying with a pick to move it the rest of the way.
    It will eventually work. If I did it, you can to.
    Bob
    • WDB_xs1100s
      • Jun 2011
      • 26
      • Ashland, Kentucky
      thanks, i need all the help i can get. im sure the broken screws will make the bike run terrible.
      • Titbit21
        • Feb 2011
        • 76
        • Kent, Ohio
        I had to deal with this about 2 months ago. Mine were really stuck, 1 of the came out with the push pin pry method. Give that a try first and try to get quality pins. The really cheap ones the plastic break easily and the pin is crap. If that doesnt work get some mechanic picks and get a little midevil with them. Whiskey helps! They will fall out with some work just dont give up.
        '78E
        • Shacknasty
          • Feb 2011
          • 379
          • SFV-SoCal
          I have used a nut and bolt as a screw jack to push the broken tip out. You need a bolt a tiny bit shorter than the space . Put a nut on the bolt and with two wrenches unscrew the nut. It will force the busted tip upwards. Go slow, use penetrating spray and a soldering iron to heat the tip. The heat will help draw the penetrating spray in and may pop it loose.
          • WDB_xs1100s
            • Jun 2011
            • 26
            • Ashland, Kentucky
            ok i got the 2 tips out and reset all the screws to 2 turns out the bike runs really good now but i cant set the idle. then i noticed the bike is smoking i looked into the megaphone and culd see oil or gas in it. i shut the bike off and wiped it out but it had no smell to it but it looks like oil or something. should i be concerned about this?
            • Shacknasty
              • Feb 2011
              • 379
              • SFV-SoCal
              Did you purchase new needles or are you using the broken ones?
                Ahhh, my thoughts exactly!
                • lee_dutcher
                  • Apr 2009
                  • 822
                  • mason city iowa
                  a box of thumb tacks and a set of mechannic picks, and something to use to push down with (flat head screw driver), beer and whisky, and patiance...if u have some..lol.. eventually it will pop out
                  1980 gs1000g "stock"
                  • WDB_xs1100s
                    • Jun 2011
                    • 26
                    • Ashland, Kentucky
                    well i hate to say that im using the old ones just as temporary(i know its not good) but i have no idea what to adjust them to when i replace them, i think i need to invest in a sync tool and color tune or are they the same?
                      Not going to get far with the the broken tips.
                      When you get replacement mixture needles about 2 turns out is a decent start but you do need to sync and tune properly.
                      • WDB_xs1100s
                        • Jun 2011
                        • 26
                        • Ashland, Kentucky
                        ok sounds good but....the one in #2 is fine and the pipe doesnt get as hot as the others. i done the little sprayin water on it, it sizzles but the other ones are so hot that the water doesnt even stay on them.
                        • Titbit21
                          • Feb 2011
                          • 76
                          • Kent, Ohio
                          Maybe the floats in your carbs are need to be set. Could be to rich in one and lean in the other.
                          '78E
