My "new" 80 XS1100 has electrical/charging issue
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    New to this site and really enjoy it! Back on a bike after 11 year hiatus. Brother in Law bought me a 1980 xs1100 in Missouri and brought it to me last Saturday. Him being certified Harley mechanic we did the things necessary to get it up and running (went thru tank, carbs, ect) and it purrs like a kitten. It did however arrive with a home made light switch/setup run directly off the battery (previous owner had charging issues) and the charging was not working. Thanks to your great site I found an easy alternator test and preformed it today. Did ohm test on stator and found it to be fine, also the regulator to my surprise was fine. Put it back together and sure enough light popped right on and it was pulling a 14.5 volts under throttle. Keep in mind I did nothing but the testing. Started it later to go for a ride and charging system down again. Performed all tests again and this time the regulator failed. No more charging or light coming on by itself. Put it back together and said the hell with it. Just went out to put it away for the night and when I started it to move it the damn light came on and the alternator is clearly working again. I'm at my wits end with this one! I'm not seeing any bad ground issues, what would be by next move. Brother in Law is 6 hours away and doesn't know much about the Yamaha setup, I'm hoping you guys can help. Thanks
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
    First place to look is the three white wire connector behind the fuse box bracket. Pull the right side plastic side cover off. Then remove the three screws holding the fuse box bracket to the side of the battery box. You will want to remove the connector to the signal flasher under the fuse box so the panel will move out of the way.
    You will see behind there a couple connectors, one of which should have three large white wires coming in and out of it. It may be burned or melted, or just corroded. It is a common point of trouble.
      • 9980
      Don't know were Winchester Ks is but there are some great XSives and XS tech people in KC and around Wichita.
      You most likely have a connector or fuse that is making intermittent contact.
      Check ALL your electrical plugs, particularly the ones behind the fuse box, to the rectifier and the fuses for good connection. The fuse panel is one of the biggest electrical problems on these old bikes. Some light emory cloth to clean all the fuse contacts and make sure they grip the fuses tightly.
      Connectors, and fuse panel is where you should start. I can almost certainly say that is where your problem lies.
      Welcome to the board Jeff.
        • 9980
        Dammit don!!!!!!!!!!
        • neJeff
          • Jun 2011
          • 346
          • Nebraska
          I don't know where Winchester, KS is either...I am from Nebraska. Anyways I guess I from what is being said I need to focus on dirty connectors / bad wiring/ cleaning fuse block and forget about replacing parts for now?
            • 9980
            Hmmmm...........could have sworn that's what it said in your location when I typed that post.
            It IS probably just a bad connection somewhere.
              Parts in general, and electrical ones in particular, typically do not work well, then not work, then wokr fine again. That is typically a tell-tale sign of a loose, bad, or dirty connection. Reallistically, it is never a bad idea to go through the entire harness and clean all of the connectors. For your particular problem, the one behind the fuse box is very often the culprit.
              • neJeff
                • Jun 2011
                • 346
                • Nebraska
                Is there a spray or dressing or something to help clean & keep clean the connectors? From what I have seen so far they look ok to the eye but is there a spray that might help? I am also changing out all fuse's. They are not blown but what the heck.
                  Deoxit I think it is called is a good electrical connection spray for cleaning. Also pack all the connectors before reassembly with dielectric grease to keep moisture and dirt out.
                    • 9980
                    Yeah Jeff, the auto parts store will have electrical cleaner around where the carb cleaner and brake cleaner are.
                    You can't always see the corrosion but it's there.
                    I hope this get's it working for ya.
                    • neJeff
                      • Jun 2011
                      • 346
                      • Nebraska
                      Damn... Deoxit... I got a can less than 2 feet away from me and never thought of it! I use it to clean control pots on old stereo equipment. I'll also pack all in the grease as mentioned. Got to get all fluids changed out this weekend too. Owned this thing since Saturday and it's already taking over my life but a great way to spend $750.00! Thanks again guys
                        Crazy isn't it!
