This one had me stumped for a while so thought I'd post this in case you're having similar problems. Rear brake switch developed an internal short to the 'pull rod', which, of course, is connected to frame ground via the spring. Viola - operate brake- blow fuse. I didn't make the mental connection between the brake and the problem right away, 'cause I lost turn, tach function, oil, neutral and stop light all at once. So wylie coyote super genius started troubleshooting inside the headlight bucket DOH!
And their a bitch to bungie down!
