Any suggestions?
  • SLB1963
    • May 2011
    • 53
    • El Dorado AR.
    Any suggestions?
    I just got my carbs back together( this is my first rebuild on a 4 carb set-up).
    I am trying to get the bike to start. It barely fires when I first turn it over but will not crank. the bike sat up for years. I had to replace the float needles and one of the pilot jets. I adjusted the floats and also found the vacume hose was plugged and cleaned it out. The bike has 1,400 miles on it so it has sat up most all its life. 1981 MS. any suggestions on how to get it to fire up or what I may have done wrong. I do not have the air filter on. I figure if it would start it would do so without it on. The bike ran 3 years ago when my Brother in law took it to the shop then he let it sit again.
    Any suggestions would be appreciated.
    [B Bone stock 1981 SX1100LH 1,430 miles bringing back to life, slowly but surely.
    1973 RT3][/B]
  • petejw
    • 2269
    • sydney australia
    hi SLB1963,
    hows the condition of the battery?
    the tci needs around 10.5 volts to fire the plugs,
    try jump starting the bike and see how u go,
    also there shouldnt be any problems trying to start the bike
    with out an air filter.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • SLB1963
      • May 2011
      • 53
      • El Dorado AR.
      Thanks for the reply, Your bike is awsome!. I have a charger on the battery and it just started running. It is backfiring at low rpms but will rev good. I will let the battery charge overnight and see what happens in the morning. I noticed the headlight did not come on when it started. another issue for another day!
      1973 RT3][/B]
      • L0rdexpectati0n
        • Dec 2010
        • 45
        • outskirts of hell,MI
        did you sync the carbs? mine was backfiring syncing help out but i'm also looking into valve lash with mine. and also running the bike without the air filter is letting the bike breathe unrestricted increasing the air flow and leaning out your air/fuel ratio
        1980 xs1100sg
          • 9980
          Unfortunatly if you are running a stock airbox/aircleaner the carbs will have to come back off to get it installed.
          Don't try to tune the carbs without whatever air cleaner setup your going to run. You will just be wasting your time.
          The air filtration system needs to be installed to get it right.
          • petejw
            • 2269
            • sydney australia
            glad u got ur bike running.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
