I had a sneaking suspicion that my charging system was not "up to snuff". I added a stereo to the bike and it cuts out when I'm at idle. It doesn't seem that a standard car stereo would be drawing that much power. I added a voltmeter into my dash and it reads quite low. I understand that a $15 Kragen meter might not be real accurate but it's reading 10 volts at idle and tops out right at 12 volts at 4,500 RPM. Voltage drops to an alarming 8 volts (intermittently) with the turn signals blinking.
The battery is almost 3 years old now. It is full of water / electrolyte. I've replaced the fuseblock with individual spade-type fuses. I really haven't gone through the rest of the wiring harness / connectors yet.
I realize that I have added a few lights that contribute to the problem ... the 2 amber running lights in the Pacifico fairing, the 2 red running lights on the trunk (same thing as the ambers), I replaced the stock 1157 bulbs in the tail / brake light with (non flashing) LED bulbs which I feel helps the situation (no voltage drop when brakelight comes on), rear turn signals converted to 1157 running / turn lights (LED bulbs wouldn't flash when I tried them here), headlight is H4 80 /100 watt, and eight 1/4" accent lights scattered around the bike (looks really cool ). I swapped the 12K volt coils with Dyna 45K volt units (not sure that makes any difference). I'm considering replacing the small incadecent running lights with LED lights os the same size (15 LEDs in a 3 1/4" x 1 1/5" panel) which might draw less current. Also, would bypassing the self cancelling feature of the turn signals affect anything? How about getting rid of the reserve lighting unit, does that unit suck electricity?
It would be nice if someone would find a stator with a lot more winding off another model bike that would work on our bikes. Guess that would be too easy and take all the fun out of tinkering with these great bikes.
Tomorrow I'll test my regulator and rectifyer and consider cleaning connectors. All suggestions will be welcomed with open mind.
Thanks guys and guyettes
