Tis the season to ride...only if the headlight worked! No pwer @ harness to fairing, took the relay out and jumped bl/blk and yel/red still no pwer Fuse good, left side @ hi-lo switch seems ok. I'm at a point of running pwer lead with a toggle from battery, any other thoughts... maybe a flashlight strapped to helmet
Headlight Woes 78 xs1100
got a 9v battery ? set of jumpers with alligator clips or something ? jump power from the battery directly to the headlight (high or low is ok) does it light up ? (bike runs right? but no headlight at the moment) try jumping it to the light and post back79 xs eleven special
pods
jetted
cammed
pitted chrome
straight pipes
16" apes
+6 front
-2.6 rigid rear (still regret this)
blinkers are for slow ppl
http://i473.photobucket.com/albums/r...1/100_3355.jpg http://i473.photobucket.com/albums/r...1st2011021.jpg
"here for a good time NOT a long time"
Its the simple things in life
that often confuse us. I had all kind sof issues gettign ym headlight to work correctly. I jumpered out the RLU as well as the relay ( you did not mention the RLU so you may want to try jumping that out). But in the end, I discovered that even though BOTH of the headlights I had the bulbs LOOKED good, in the end, both were busted. New bulb and I had a nice functioning headlight!!Life is what happens while your planning everything else!
Originally posted by DGXSER View Postthat often confuse us. I had all kind sof issues gettign ym headlight to work correctly. I jumpered out the RLU as well as the relay ( you did not mention the RLU so you may want to try jumping that out). But in the end, I discovered that even though BOTH of the headlights I had the bulbs LOOKED good, in the end, both were busted. New bulb and I had a nice functioning headlight!!79 xs eleven special
pods
jetted
cammed
pitted chrome
straight pipes
16" apes
+6 front
elimination process
I suspected the bulb early on so failing to mention, I took the bulb out and jumped it to a 12 volt source and the bulb works fine. I'm using a replacable bulb rather than a sealed beam! Not sure how to jump out the RLU, my thoughts are leaning to the ignition switch? although the white light on the instrument panel did not indicate /No headlight. Voltmeter check @ headlight relay(absent) is nothing for power?
Originally posted by angelican View PostI suspected the bulb early on so failing to mention, I took the bulb out and jumped it to a 12 volt source and the bulb works fine. I'm using a replacable bulb rather than a sealed beam! Not sure how to jump out the RLU, my thoughts are leaning to the ignition switch? although the white light on the instrument panel did not indicate /No headlight. Voltmeter check @ headlight relay(absent) is nothing for power?
if the light turns n with the ground jump *ding problem solved(find the fail in ground side of circuit)
if it fails to illuminate ,with it conected as mentioned do you have available voltage @ the light power lead in?
any short to ground before the light would create a open without load (lets the magic smoke out)
fyi a relay has a low amp side that creates the field that allows us to operate a high current circuit with low current...define absent please?79 xs eleven special
pods
jetted
cammed
pitted chrome
straight pipes
16" apes
+6 front
You're jumping the wrong wires at the relay; the yellow comes from the alternator, the black is ground, and you need to jumper the red/yellow and blue/black. This should immediately turn on your gauge backlights, and sends power to the RLU. If no headlight is hooked up, the 'headlight' light should come on. You should also have power at the blue/green and blue/yellow wires at the RLU. These then go to the handlebar 'hi-lo' switch, and from there to the headlight. When you change the switch, the high beam indicator should change. If not, (and if you haven't already done so) remove/disassemble/clean the hi-lo switch. Also check the connections where the handlebar switch plugs into the main harness. If the high-beam indicator and headlight fails to light at this point, the RLU has probably failed...
There's quite a few errors in the early wiring diagrams, and the lighting circuit is one of them...Fast, Cheap, Reliable... Pick any two
Even the one link on the site is wrong for 78 and 79. I had alot of headlight issues until I searched and found the correct set up the bypass that works on the newer ones wont work on the 78,or 79. It lets both dim and bright be on at the same time. I burned through quite a few bulbs before I found out ..." She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
