Wtf.....
  • Incubus
    • 1003
    • Austin TX
    Wtf.....
    So it's Republic of Texas Rally weekend here is Austin (and also MOM) and the streets are filled with cycles of every kind (mostly Harleys ridden by insurance salesmen dressed in biker drag, but....) so my wife commuted with me to work today, stylin' on my vintage scoot. Everyone was impressed, even people who didn't see the bike but somehow intuited its presence. Pretty cool.
    So I get her to work (27 miles, one-way) and they've got these huge, mountainous traffic bumps - I'm talking snowcaps here, even at 100 degrees - and....
    OK, only loosened the exhaust a little. Figured it might run a bit rich on the ride home. So this afternoon we set out for home, wending our way through bevies of bikes, and the bike is running fine, if sorta hot. Traffic is almost deadstop on I-35, so I'm doing a lot of 1st and 2nd gear driving. Suddenly, I heard a little "poof" and left a little blast of air on my left leg. After that the bike is running like crap - it revved fine and ran on the highway fine, but driving at the bottom end of the range was rough and idling was ridiculous. I figure it's the exhaust, no real back pressure, and lean conditions.
    So tonight I remount the exhaust. I start it up and I hear "poof" "POOF" "poof." I look down, and I see this....
    So I think I can figure out the fix, but I am wondering about the cause. Aren't this ports supposed to be like a really bad relationship and just suck all the time?
    This will not keep me from MOM...
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    Looks like you just had an old hardened vac cap. The heat does that to em.
    That usually happens when you have an intake backfire. You might need to tune on the carbs a bit more. It might be a tad lean.
    I had several blow completely off when my carbs weren't quite right. I have several extras in my tool bag now and I've never need one again since tuning.
    Go figure.
      Chances are the vibration caused the cap to bust and give you a vac leak. The leak made it lean giving you the popping.
      • xs11lover
        • 1433
        • Montoursville Pa
        Isn't that the one that hooks to your pickup coil hose. Mine popped of one time too. Couldn't tell you why but it never happened again. My guess is Harley scum were messing with yer bike.
        79 XS11 Special (Lazarus)
        79 DT 100
          If your pickup coils are hooked up to a car intake boot you have a whole different problem. They should be hooked up to the nipple on the #2 carb!
          • jwhughes3
            • 2798
            • Home of the Alamo
            bring it to MOM!
            ha! all those Harley's made you "bust a cap"
            BTW - good call on not intimating that it was the 2-up weight over the speed humps that made you bottom out - you'd never survive
            really - bring it over so we can have some fun.....
            @nate - what pickup coil vacuum do you speak? I thought the pickup coil was wire and ran electricity?
            now I am confused - my #2 vacuum nipple runs vacuum to the petcock like #4.
            John
            '81 XS1100H - "Enterprise"
              John
              xslover referred to it as that so I just left it that way for simplicity in realizing I was talking about the same thing as he. I am guessing he was referring to the vacuum advance which should be hooked to the #2 carb.
              • 81xsproject
                • 3185
                • Fortuna, CA
                If you want to avoid this in the future, you can do like I did. Get your self and M3 tap and very gently thread those on the inside. Then I would use a little thread sealant and screw in some very short M3 screws. I f you dont want to see them, you can put vac caps over them.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                  • 2117
                  I got vacuum caps that were a tad loose so i put a zip tie around them and clamped them tight-hasn't come off yet!
