I think I have symptoms of a pick up coil wire problem but not sure. In neutral revs up very nice. when riding it and accelerating fast above about 3500 it seems flat/miss until about 5000 and then it takes off like a rocket. If I accelerate slower it doesn't seem to be flat/miss during the midrange described above. carbs have been cleaned, timing is right on and advance works (although I have not checked it yet with a vacuum pump). sound like it could be pick up coil? doesn't run right at midrange but upper range is normal?
1978 XS1100 all stock.
