This is my first post, so, i'll try to be as descriptive as I can.
My ride is a daily drive to work every day, 30 miles oneway almost all interstate. It all started when i would lose a couple of cylinders in the rain. I thought it was just water issues with the fuel and/or the electrical. It wasn't until it started doing it on dry days that I found the problem. After searching this site, I decided to check the pick up wires. Sure enough, I had an open. Here's where I think I screwed up. I might have rotated the crank the wrong direction while messing with the vac advance. I noticed that it was a little sticky and was trying to figure out how it comes off, and rotated the crank.
So, I fixed the wires, went to go restart the bike to see if it runs better and it wouldn't catch. I thought it was flooded, so I went wide open on the throttle and full choke, then crank, crank, crank, bam! one backfire! WHOA!
Okay I let it sit for a while, again thinking it was flooded. Tried it again, this time boom, the forward(Exhaust) cam plug blew out and hit the side of the house. Freaked me out. The bike ran (barely) and there was some gasses escaping from the plug hole. Back to the forum and a whole lot of reading on the cam timing issues.
So, this is where I'm at now. My thought is that I might have slipped a tooth on the cam. I plan on taking the valve cover off, checking the timing marks, checking the valve clearances, setting the tensioner, doing a compression test, lubing the vac advance, then trying a carb sync.
Anything like this happen to any of you guys?
Did I miss anything else I can check?
Thanks, this forum is great for all of us XS owners to share our experiences and expertise.
