I decided to take advantage of my day off and take a relatively long bike cruise. Of course, about 2/3 of the way through SOMETHING had to come up.
Here's the deal:
Relatively short rides (30-45 minutes) are fine, no problem. But twice now when I've taken a trip of an hour or more, the engine starts acting up. It seems like I drop a couple cylinders, and at speed (55/60 mph) it starts backfiring like crazy. I've usually be able to pull the clutch in, let the motor drop to ilde RPMs for a minute, then rev back up and it's fine (apart from a "pop" or backfire).
I thought it might've been a heat issue, because it was easily 95 today, and the few times I let is sit for a bit to cool down, it seemed to run better for a while. In addition, short rides don't have the same problem.
I'm thinking it might have to do with the pickup coil wires. The symptoms seem identical, and I DID have to re-solder them already. I wouldn't think the heat would mess with them, though.... I'll pull the sidecover anyway to check it out, but I figured I'd get your opinion as well.
