Bike revs high at idle
  • MeatTooth
    • Apr 2009
    • 175
    • Tulsa, Oklahoma
    I was wondering if anyone has had this happen....... When I first start my bike it revs pretty high like around 1500 to 1900. When it warms up it drops down to idle around 1000 1100. Well today it dit it like normal but when I took it off the kickstand and stood it upright it reved on it's own back up to 1900 for a little bit then dropped back down. I took it for a ride and it has very little acceleration and around 5000 and on it was kinda sputtering and cutting out (no popping). Any insight into this issue would be appreciated.
    Tulsa, OK
    That non-exhaust might have something to do with it... These engines need some back pressure from a real muffler to run properly. Have you re-jetted your carbs at all? Have you sync'd them as well?
    Normal idle is 1100 RPMs. Adjust that down, and go from there.
    • MeatTooth
      • Apr 2009
      • 175
      • Tulsa, Oklahoma
      I've rejetted with the dynojet stage 3 and resynced. The mufflers are straight through performace but they do have 12inches of baffles in there that choke down to about 1.5.
      Tulsa, OK
        Might have a vacuum leak, check those rubber caps on the carb boots, JAT.
        • jwhughes3
          • 2798
          • Home of the Alamo
          C-bug you got me!
          I kept trying to kill your avatar till it dawned on me...
          john
          '81 XS1100H - "Enterprise"
          • MeatTooth
            • Apr 2009
            • 175
            • Tulsa, Oklahoma
            I'm going to put in the stage 1 jets tonight and see what happens. I have my colortune in the mail so it'll get there eventually.....I'll also check for a vac leak in the meantime. Thanks guys
            Tulsa, OK
            • jwhughes3
              • 2798
              • Home of the Alamo
              dynojet
              what is a dynojet?
              john
              ps - i like your seat.
                JW..........that is a place you REALLY don't want to go to..........unless your bored to tears and like tinkering......me, turn key on....hit START and ride.......also, a spare set of GOOD carbs makes for a good backup before doing the dynojet thing......once done, can't go back.....
                • petejw
                  • 2269
                  • sydney australia
                  hi MeatTooth,
                  the dj stage 3 kit is to big for our bikes,
                  even with straight thru exhausts and pods,
                  try the 124 or 128 main jets, also clean/replace the
                  spark plugs after any changes.
                  also hard to tell by the pic but the air box uve
                  made up on the bike might not be doing the engine any favours,
                  as does the exhaust as bug stated.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    I was thinking that as well. Could be that carbs 2 and 3 are getting most of the air and 1 and 4 are starving a bit, that is unless you put runners inside the plenum to account for this.
                      what is a dynojet?
                      Dynojet is a company that makes a bunch of different racing-tuned parts and kits for various things. One thing they make is a carb jet set for our bikes. It includes new slide needles, main jets and air jets, along with a drill bit to increase the size of the hole in the slide for air passage (makes the slide move faster). That last item is the only part that you cannot un-do once you've installed the kit, but I've heard that some folks just do the hole drilling without the kit and see improvement in throttle response.
                      • MeatTooth
                        • Apr 2009
                        • 175
                        • Tulsa, Oklahoma
                        Thanks for the help
                        OMG!!! it's alive! Pulled out the 138 mains and put in the dynojet 128s. Drained all the gas, cleaned carbs and put in some no ethanol 91 with some seafoam. Checked the plugs and they were some weird ngk type so bought the correct ones and they are about1/16 inch longer reach than the PO plugs. Synced the carbs adjusted the mixture screws to 3 turns out and went for a ride..............HOLY HELL this thing has violent acceleration. All of a sudden things were happening way too fast. I was about to give up on this one and sell it as will idle but won't drive. Thanks for the input guys.
                        Tulsa, OK
                        • cywelchjr
                          XS-XJ Super Guru(Deceased)
                          • 4450
                          • Sacramento, CA
                          I'm not sure what you mean by some weird NGK type plugs, do you mean the wrong NGK plugs? as the OEM plugs are NGK. I'd be careful about length unless your 100% sure the others were the wrong ones, cause too long and the pistons could kiss the plugs and you won't like the results of that.
                          • MeatTooth
                            • Apr 2009
                            • 175
                            • Tulsa, Oklahoma
                            No I put the right plugs in (I checked the NGK website before installing). The PO had the wrong plugs in. They were weird looking because the electrode was buried up in the threaded part and the plug reach was very short compared what NGK called the right plugs. I tried to find the part number to see what they went to but had no success.
                            Tulsa, OK
                              Just in case. BP6ES is the correct NGK plug.
