Yes I do. 78E with Jardine 4-to-1 pipes. Standard airbox with washable K&N filter. NICE low end torque.
Originally posted by pgg
The 'twitching' below 3000 revs is caused by the overlap from the cams causing a small 'blowback' into the carbs. Overlap equals inlet and outlet valves momentarily open together. The larger the cam duration , the larger the overlap. Once the revs are up and the cams 'come on,' everythings sweet and smooth. The earlier 78e's have a higher duration and I found my 78e's were twitchy below 3000, no matter how much carb tweaking I tried. Anyone out there had a 78e with grunt below 3000?
