Will it leaf me by the road....
  • Incubus
    • 1003
    • Austin TX
    OK, bad pun. I plead no contest....
    Doing my semiannual tuneup on Incubus today. I pulled the No. 4 plug to check it. It's a little breezy today. With the plug out, while I watched in horror - frozen in panic, mouth agape, a low moan turning into a soulful wail - a little dry leaf blew into the spark plug hole.
    OK, guys, how many contortions do I put into getting it back out? Think it will blow out the exhaust port the next time I start the bike?
    Crap.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • bobber
    • Dec 2008
    • 82
    • los olivos. ca
    the leaf
    take all the plugs out,and turn her over a few times,might blow the leaf out.
    if not,it will burn up on combustion. i would n't worry abut it
    1978e. special forks.she's a frankinstien.a bit of this a bit of that.its a monster
      • 5061
      It probably will help the energy of the combustion for one fire of the cylinder!
        Leaf it alone and it will blow home, wagging its stem behind it!
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          I would not in the least worry about a little leaf getting into the cylinder through the plug hole. That's not going to block anything, and the fire will cause it to burn and while it might cause a backfire or two if anything, even that it unlikely as it will most likely go right out the exhaust valve on the first full cycle of that piston, if not, it will be ash within 2 or 3 cycles anyways and then it will be gone.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            GROAN! Just because he did it, doesn't mean you have to.
            CZ
              • 5061
              CZ
              Gathering a pile of leafs right now!
              • jwhughes3
                • 2798
                • Home of the Alamo
                you must be careful
                whenever the spark holes are open... many leaves are sad to be separated and will seek out the valve stems looking for some semblance of their former life...
                you were lucky this one didn't bring friends.
                next time stay sober, your reaction time will be quicker!
                LOL
                ok I guess I've had my fun at your expense. I relinquish the floor.
                john
                '81 XS1100H - "Enterprise"
                • Incubus
                  • 1003
                  • Austin TX
                  I had a feeling someone could limbo under me with a worse pun. I knew I could count on you guys.
                  Thanks for your responses. I took it for a ride this evening and felt no ill effects.
                  Patrick
                  1969 Yamaha DT1B
                  • cywelchjr
                    • 4450
                    • Sacramento, CA
                    Patrick
                    The shower of sparks out of the exhaust would be it leafing you.
                    • Smash
                      • Aug 2010
                      • 257
                      • Denver, CO
                      BWAHAHHAHA ok this thread made me laugh.
                      Two weeks vacation does NOT make a life.
                      His: 2006 Ninja 650R, salvaged, 10k miles
                      Hers: '82 XJ1100 44.4k miles
                      • geobiker
                        • Mar 2010
                        • 82
                        • Pa
                        Okay
                        Boys, enough said, time to leaf this thread alone!
                        1979 F
                        Mac 4-2 Exhaust
                        T-Kat Fork Brace
                        Spade Fuse Box Mod
                        Stainless Steel Braided Brake Lines
                        140.0 Main Jets
                        45.0 Pilot Jets
                        266 X-2 Needle Jets
