Charging... Except not...
Well, the bike is running awesome, except alittle clutch slippage (have new disks to install) and charging. I tested the generator its doing fine. When I take the bike for alittle spin its actually discharging the battery? Whats the best method for testing the voltage regulator. I should also mention, when the bike last broke down, the battery was spewing acid from over charging. Anyone have any directive tips?
Anywho, Nate is correct, check the voltages and if they are good your probably fine, if not then check that connector FIRST, if it's good then your into getting deeper into the system when you get back from your trip. We can help you get through it, there are more than one of us who have troubleshot charging issues with some measure of success.
