So I took apart and cleaned my front master cylinder and there was a hole in the seal that goes in after the spring. I put it all back together and thought if it was a problem it would leak. Well now my plunger/piston wont return when I press the brake slowly. If I do it quick it will bounce back. Any ideas on the problem. Also...
I pressed the brakes while the pads were off and the cylinder was stuck out. I used a c-clamp to push it back, but as soon as I tried to bleed the brakes (before I read about the plunger on the MC piston coming undone) the pads were stuck in. So now I have the pads stuck to the rotors, and the MC piston won't return to its open position after I press the brake. Fluid is going thru the lines as when I open the bleeder it comes out when I squeez the brake. Is the MC piston assembly just not lubed enough hence the sticking or is it a weak spring? Or something I haven't thought of *sighs* This is becoming quite the carb rebuild, new tires and brake pads quick fix LOL!!! HELP ME!!!!!
I know you will, but MAN DO I WANNA RIDE....safely tho
I pressed the brakes while the pads were off and the cylinder was stuck out. I used a c-clamp to push it back, but as soon as I tried to bleed the brakes (before I read about the plunger on the MC piston coming undone) the pads were stuck in. So now I have the pads stuck to the rotors, and the MC piston won't return to its open position after I press the brake. Fluid is going thru the lines as when I open the bleeder it comes out when I squeez the brake. Is the MC piston assembly just not lubed enough hence the sticking or is it a weak spring? Or something I haven't thought of *sighs* This is becoming quite the carb rebuild, new tires and brake pads quick fix LOL!!! HELP ME!!!!!I know you will, but MAN DO I WANNA RIDE....safely tho
