Windjammer SS Electrical Color Codes: (Click the link to get a neater version...all the way to the bottom)
Fairing Wire Function Bike Wire
White High Beam Yellow
Yellow Low Beam Green
Black Ground Black
Violet Left Turnsignal Brown
Blue Right Turnsignal Dark Olive Green
Green Running Lights Blue
With the above setup, the following is the result:
Left front running light
Left front with Right rear signal (signal is very slow, but bike isn’t running)
Left rear signal by itself
No dash lights
Split the green to go to both Blues
Right front running
Left rear running
Left rear signal
Dash Lights
Switched Brown to Blue and Dark Olive Green to Violet
Left and right front running
No dash lights
Left and right running
Left rear signal
No dash lights
NOTE: White, Yellow and Black are not connected during this test. Could this be the cause of the problem?? (There is a good reason why they're not connected)
NOTE: The original Yamaha fairing had the green wire split to go to the two blue bike wires.
Black Ground Black
No dash lights
Right front running
Left rear running
Left rear signal
Dash Lights
No dash lights
Left rear signal
No dash lights
