Caliper rebuild question
  • KA1J
    • 664
    • Groton, CT
    Finally done with the front rebuild. Thanks for the pointers! I have enough brake lube to last a lifetime. I bet that stuff is good to use when getting the carbs in the boots.
    Hoping the pistons went in properly & I didn't roll an O-ring, can't tell till I fill them. Will do the rear next.
    Now comes the joy of figuring out how to remove the remaining 4 brake hoses the easiest way. The MC/Proportioning valve looks to be really tightly packed in there.
