popping - more tuning needed
  • kevxs
    • Apr 2009
    • 353
    • toronto
    hey guys the bike is running pretty good but it is popping and backfiring during acceleration out the left pipe mostly when under 3000rpm.
    this only happens for the first 10mins, once it is warmed up it hardley happens at all.
    there is no popping during engine braking.
    the plugs look a little rich.
    any suggestions?
    thanks!
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
    Did you sync and colortune? Sounds like you need to adjust the fuel/air mixture screws a bit (aka colortune).
    • kevxs
      • Apr 2009
      • 353
      • toronto
      naw i've only done a bench sync (last season). don't own a sync tool or colourtune. i wonder if these can be rented? haven't got much time to build the sync tool, renting one would be nice
      Green Dyna Coils
      1973 CB100
      kevXS
        I've never known of a place to rent a sync tool, but that doesn't mean you can't... However, if you own a bike, you should also own a sync tool of some kind. You can make one in an hour or so by following one of the many descriptions here on the forum. Colortune plugs are almost definitely non-rentable. You can tune by ear if you know what to listen for (there's a tech tip about it). However, a proper sync is essential, and should be done EVERY TIME the carbs are messed with. As far as I'm concerned, if you take the carbs off the bike for ANY reason (even if you do nothing to them), you should sync them again.
        If you have the funds, the very best setup can be purchased from the UK via carbtune.com. Be sure to get the storage case for it too. This is also the same place to buy the Colortune plug.
        • TomRodgers
          • Jun 2008
          • 492
          • La Porte Indiana
          I kinda agree with C Bug.... jury not in about sync'n after doing nuthing to them, but its so easy to do with guages, why not...
          I do hafta say the Carbtune setup is WAY nice....very compact, very light, and even with my hand bandaged up from surgery, i sync'd the carbs with no problem!!!!!
          Definately worth the money. not that i have spent it yet....
          In your area, use this forum, Facebook, or flyers at the store to see if anyone in your area has one. One of my co-workers had one and he let me borrow it.
          '81H (my first XS ) "Grey Ghost"
          4:1 Jardine w/ headerwrap
          Windjammer(wiring issues)
          New paint/brakes to come!!
          '80G FrankenBike (parts bike)
          '80G to fix "BlackSunshine"
          Stock Pilots/125 mains
          Pod filters; 4:1 Kerker??
          SS Brake lines w/ new M/C's
          LED Brake Lite
          Needs paint....
          • anarchy18
            • Sep 2011
            • 134
            • Germany
            Help with a synchronizing tool
            QUESTION: Bought this carbtune unit and when i hook it up im barely getting any kind of reading, gotta rev the motor high enough to wake the whole neigborhood to have the bars raise up. And 1 of em isnt coming up far enough to tell anything at all. How do you use this thing you got any tips? Thank You
            '81 Yamama XS1100 5K7 German Model
            What's the difference between erotic and kinky?
            Erotic = using a feather
            Kinky = using the whole chicken
              Sometimes if you are running lean at idle you won't really be getting much vacuum. Opening the idle mix screws will usually result in the vacuum coming up. Also you want to have the idle as low as you can get it when using it.
              That said, it only works really at idle because the vacuum goes down as the rpms go up.
              • mack
                • 2411
                • Ontario, Canada
                Ontario riders
                There are a few guys in your area. PM tinman or Bullet and ask if you could swing by and use theirs. I'm about 1 1/4 hour from you. If you want to take a run down here, I'll do it with mine.
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                  You may have some major vacuum leaks. Make sure you have the restrictor valves in the hoses, about 4" from the carb boots. Keep idle at 800-1000rpm, or as low as you can while performing the sync. You'll find that the better the sync is, the lower you can turn the idle speed and still have it idle well. While idling, with all the hoses connected, try spraying some starting fluid around each carb boot to see if the RPM changes. If it does, that means there's a leak, allowing the starting fluid to get sucked into the engine. Solve that leak first.
