Hi guys, I got my Uni pods in today - black foam and chrome caps. Looks and sounds great. Runs a little rough below 3k rpm, but I'd attribute that to the fact that I had the carbs all apart and didn't get my synch tool in yet, nor have I adjusted the idle screws. Pulls HARD from just above idle to 7k rpm (the highest I brought it). I have the new jetting as described in my signature so I'm going to pull the plugs and see what things look like.
The Uni's DO have a lip inside but it's recessed 20mm but they can only slide onto the carbs 10mm so it appears there is no problem with that.
After oiling the filters I cleaned the inside of the rubber lip and the outside lips of the carbs with degreaser. Even with minimal tension on the hose clamps they are next to impossible to pull off so it looks like they'll stay on good. Time will tell. Overall, very happy so far.
