Hi all,
After replacing my fork seals with new ones (pyramid parts), they are still leaking. I noticed this is particularly bad after I put any air on the forks
(normally about 7 lb). Trying to fix this, I noticed two things -
First, should I be able to see the coiled spring inside the seal? I suspect that I installed them upside down.
Second, after reading, it seems like there is a special seal recommended for air forks, a triple-lip seal? Does anyone have a photo so I can compare it to my seals?
Because I run a Windjammer fairing, I would like to stiffen up the front end and improve handling, but at this point it sounds like I'm going to have to put in progressives and maybe cartridge adapters or a fork brace to get the handling back to where it should be. Any recommendations?
Thanks,
(normally about 7 lb). Trying to fix this, I noticed two things -First, should I be able to see the coiled spring inside the seal? I suspect that I installed them upside down.
Thanks,
) If your fork tubes have a few dings/pits in them, then I would go with the Leak Proof brand. As for stiffening up the front end, either get some heavier springs, or add some preload spacers to your existing springs and/or try a heavier oil, 15 or 20 weight. Increasing the oil level slightly will reduce dive on braking. A fork brace and emulators are also a great improvement for these bikes.
