Middle gear & final gear oil
  • KA1J
    • 664
    • Groton, CT
    I used Mobil-1 Synthetic hyphoid in my cars rear end, any problem with using it for the XJ11 middle & final gear oil?
    Thanks
    • 8891
    No problem using synthetic gear oil, I use it as do many other members here.
    • Smash
      • Aug 2010
      • 257
      • Denver, CO
      Yep! That's what I've always used in my final drives.
      Two weeks vacation does NOT make a life.
      His: 2006 Ninja 650R, salvaged, 10k miles
      Hers: '82 XJ1100 44.4k miles
      • KA1J
        • 664
        • Groton, CT
        Great!
        I probably have enough on hand to do the job.
        Thanks!
