blown diaphram?
  • mack
    • 2411
    • Ontario, Canada
    blown diaphram?
    Well, started the diagnostic on the fuel situation. Vacumn lines are clear, tank vent is clear, petcocks are flowing, pulled the forward lines off the petcocks, turned them on with no fuel flow, sucked on the vacumn line and only got flow out of right side. Blew on vent lines and are all clear. Removed ther octy and could blow through easily. Removed filters and could blow theough. Hooked it back up and ran bike for a bit. Right side filed filter, left side not so good. Watched the level drop. So left side seems to be weak. Blown diaphram in #1 or #2?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • 11Rider
    • Aug 2010
    • 331
    I'm not understanding what you mean when you say "right side filed filter", but it sure is easy enough to take the tops of the carbs off while they're on the bike and check the diaphrams. About the only thing you have to do first is take the tank off. If you do have a bad one, I remember reading a post not too long ago about a way to repair them with some kind of rubber spray coating.
    '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
    Purrs like a kitten, runs like a scalded cat
    • g15usmc
      • Nov 2010
      • 365
      • 29 Palms CA
      Are you talking about inline filters? off the octy?
      Daily Driver - '04 Suzuki Marauder 1600
      Project Bike - '79 XS1100 Special
      Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
      Ride Till You Die!
      "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
      “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
      "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
        Maybe tower filters in tank a bit restricted?.........weak vacuum on octy(crack in a vacuum hose)........JAT.
        • g15usmc
          • Nov 2010
          • 365
          • 29 Palms CA
          if this is the case i would try running petcock to filter to carbs and see what happens...if that works, ur problem prolly lies with the octy and not the carb...I know you said you tested the octy but what you describe is exactly what was happening with my bike before i removed the octy...and according to the testing i did the octy was work properly...but for some reason i was not getting enough fuel in those two carbs...take the octy out of the equation and bammo bike runs like a charm...except now i have to rebuild a petcock...BLAH!
          Ride Till You Die!
          • mack
            • 2411
            • Ontario, Canada
            Yes
            after the octy, just before the carb inlet T's. In line filters both sides. Fuel flow at petcocks unrestricted.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • g15usmc
              • Nov 2010
              • 365
              • 29 Palms CA
              try my above comment...dont know if u saw it already is reason for this post...hope its just the octy...less to deal with that way...
              Ride Till You Die!
                +1 on getting rid of the octy. You can cap the front outlets of the petcocks and run the rear lines to the carb T's, then run the petcocks in the on or reserve position. That octy has left me stuck out in the middle of no f'n where before, I'd lose it, JMHO.
                • mack
                  • 2411
                  • Ontario, Canada
                  Could be the octy
                  I just can't figure out why one side flows and the other doesn't. You'd think that when they crap out, no fuel would flow, or worse it would flow all the time. So when you cap off the forward petcock line. What are you using to cap it off?
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                    Don't use vacuum caps, the fuel will eat them up. I use a short piece of fuel line with a bolt stuck in there. Saw the threaded part of the bolt off and use the shank and the head. Another way is to stuff a ball bearing in a piece of fuel hose.
                    Edit: Mack, don't forget to turn your petcocks to the off position when you're done riding.
                    • SFerinTEXAS
                      • Jun 2006
                      • 877
                      Either side petcock in the correct position and fuel hoses plumbed correctly on a SF with an OE octy will feed all the carbs. I don't use the front nipples on my SF tank valves but do use (and value) the purpose of the octy
                      I will suggest what you think to be a fact is not true. Question your previous conclusions.
                      79SF
                      XJ11
                      78E
