New Yamaha Black
  • New Yamaha Black
    Anyone have a source for the powder coat paint?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, if you're looking for this to refinish your sheetmetal bits, I wouldn't recommend it. Powdercoat, while an excellent finish in the right places, on large-area parts (like fenders and fuel tanks) it will micro-scratch and tend to dull rather quickly. Great for things like frames, engine covers, and brake calipers where durability and chemical resistance is more important than surface finish (it's got to be best thing going for battery trays..).
    As far as color selection, it's limited. Powdercoat can't be 'mixed' like paint, it has to be manufactured in a specific color. Solid colors are the more durable; anything with a metallic content or clears will mar/discolor much easier.
      Head
      Thanx Steve, I always pay attention when you chime in. I have to redo my head to match from my jugs down. Long story but excessive head caused the paint to flake off. Looks like sh..t. Going tp bead blast it and want to get a close match.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Mack, don't scoff, but my black paint of choice for barrels/heads is any quality oil-based paint in a can. Yep, I brush it on. I've never had any luck with spray paint, as no matter how hard you try, you just can't get it into all the nooks/crannies with even coverage. With a brush, you can get a good coating into those places if you work at it, and if cured right, is very durable. And touch-up is a snap... because it's oil-based, any slight grease/grime will get 'brushed' into the paint and won't cause an issue with it lifting.
        I've done this multiple times, and have always been happy with it. I did my XS2 650 this way, and with occasional touch-up, after six years it still looked great when I sold the bike.
        If you go with powdercoat, try to find the exhaust-rated powder, otherwise you may get discoloration.
          Also, touch ups are impossible for powdercoating. With paint you can always put a dab on a chip, with powdercoating you cannot.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            Yep, there's alway that. But properly-applied powder is nearly bulletproof; but if it does get flaws, the only fix is a strip/recoat. And getting it off is a major PITA... BTDT
              found one
              Found a close match, it's a powder and the color is called mirror black. I looked at it on a set of aluminum rims and it is very very close. Going to give it a try, if I don't like it, I'll rebead the darn thing again and go with your tip on oil base. Did the exhausts with ceramic and I hate the result, they're black but dull and have a grey hue to them. Going to bead that off as well, and go with expense of black chrome dipping.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                "Excessive head?" I did not think that was possible....
                If you need to remove powdercoat, Aircraft paint stripper takes it right off. I used it many times during my "learning how to powdercoat" period.
                Patrick
                XS11F (Incubus, daily rider)
                1969 Yamaha DT1B
                  Nice catch
                  Nice catch Patrick. Your absolutely right. No such thing.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
