You guys are the best. I took the carbs apart and rejetted (45 pilots and 140 mains). I put her all together and turned on the gas, when no more gas was going through the filters I hesitated for fear of being disappointed that she wouldn't fire up - BUT! One crank and VROOOOM! Choke off in 15 seconds, revved great. Took her for a spin up and down the driveway and WOW! I can't rider 'er much because I have no filters on right now (pods on the way), but THANKS TO YOU GUYS- Success!!
OK, one issue though, I can't get the throttle cable short enough. Even with the idle speed all the way down and the throttle cable adjustment all the way in, there is no free play in the throttle movement and she idles at about 2,500 rpm when warmed up. The throttle cable was fine before I took her apart. I did have to do some fancy routing because I also changed the bars to shorter ones, but I only have about three bends total and they're very mild. Any suggestions?
PS I'm going to have my son post a pic. I'm thinking I'll call her "Beastly". Your thoughts?
