Side Gap Plugs
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Side Gap Plugs
    I got into a tinkering phase awhile back and tried something I used to do when I raced Super Stock a long time ago before the high-power ignitions of today were available (back when your handicap was the national record and not a class index). Alot of us used to side gap spark plugs to get a fatter spark from our weaker coils, kind of like what the expensive platinum and iridium plugs claim.
    So I took a dremmel and cut back the ground strap from an old set of plugs and tried them out. You could actually tell the difference. performance seemed a bit more crisp.
    Pic is not very clear but you get the idea.
    The thinking is that since the spark generates more from a sharp edge, a coil will start and continue the spark more easily (from the center of the firing tip to the corner of the ground strap). And since the ground strap is moved back it makes the spark grow into a fat curve instead of just a spark between the two pieces of metal. Also, since the spark is now unshrouded it lights off the fuel/air mixture quicker.
    Down side is that your plugs might only make it for about 8,000 miles or so instead of the usuall 10,000 I get. Still, it is a fun tinker to try and it might be worth an extra HP or two.
    Mike Giroir
    79 XS-1100 Special
    • 8798
    Yep, I run 'em that way too. I also notice an overall improvement. I have mine angle gapped at about .020" with XJ 3 ohm coils and .030" with my 3 ohm Accel Supercoils. Good tip Mike.
    07 Triumph Tiger 1050
    • XS1100 Newbie
      • Jun 2009
      • 1106
      • Battle Ground, Washington
      Wow! I had not remembered that. We used to also file the tip of the ground to a point, but it ate it up fairly quick. Thanks for the reminder, out to the bike i go.
      1980 XS1100LG Midnight
      1991 Honda CBR1000F Hurricane
      A cold beer and another one!
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        I may try this with a used set... not sure I want to do this to a new set. Can you explain the gap measurement you are trying to achieve and how to measure it?
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          • 8798
          The Hartford, Wisconsin's 4x4 and Performance store on-line! Tons of great info, products, custom designs and thousands of incredible photo's...
          • davidsymons53
            • 197
            • Peterborough, Ontario
            Good tip. I'll try it.
            David
            1981 XS1100 Special
            Previous Bikes
            1999 Honda Goldwing Aspencade 1500
            1983 Honda Goldwing Aspencade 1100
            1982 Honda CB900c
            1984 Honda vt750 Shadow. My son's bike now.
            1984 Honda vt500 Shadow
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              Plugs are cheap, I may pick up a set of NGKs and set them up side gapped and pop them in and see how it runs. Of course I'm thinking I'm going to pull my coils and check for cracks, I suspect I have a crack in one like cbug does, but I think I'll use high temp RTV if I do rather than JBWeld (I'm sure the JBWeld would work, but the RTV would be more flexible I'm thinking and just as durable in the particular use).
              But I'm not do for a plug change for a while yet, but may do it anyways for the group ride I've got coming up next month and see how it runs.
              • petejw
                • 2269
                • sydney australia
                we did the same thing back in the 80's and
                id forgotten about it til bikerphil posted the tip
                a little while back.
                i also index the plugs, works well.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  Very nice! This one definitely deserves a place in the tech tips section.
                  • rman
                    • 228
                    • Stroudsbug PA
                    What is that?????
                    Trying not to offend since Aug 28, 2010
                    Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
                    Owner of:
                    1979 XS1100F (The Pig)
                    140 mains
                    45 pilot jets
                    Floats at 24mm
                    Running Rich
                    "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
                    • petejw
                      • 2269
                      • sydney australia
                      Originally posted by rman
                      What is that?????
                      indexing the plug is lining up the gap of the spark plug
                      so its facing the combustion chamber,
                      pretty much looking at the plug in the engine in situ , the
                      earth strap would be facing at 6'oclock.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Don't you have to use shim washers to achieve that?
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • petejw
                          • 2269
                          • sydney australia
                          u can do,
                          or u can just buy a few extra plugs and try
                          different fitments which i do.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • TADracer
                            • 1417
                            I would try it on a used set first instead of dicing up a new set pf plugs.
                            I tried it with a .025" gap set with a feeler gauge at an agle between the tip and the strap. After you run them for a good ride you can see a little line in the firing tip where the spark generates. That is probably where the plug will erode the fastest.
                            Mike Giroir
                            79 XS-1100 Special
                              Had some old plugs to play with. First plug, hit the electrode. Second plug seemed to work ok. Third plug dropped on the strap. Gave up after that.
