Brake line replacement
  • KA1J
    • 664
    • Groton, CT
    4W1-25873-00-00
    I'm replacing the rubber hoses with SS braid lines on the XJ11 brakes. Using this parts page as a guide http://tinyurl.com/65duhwv I have replaced the right front hose #10
    I now need to do the left side. Part #11 is next to do but I don't know if part #20 and #23 which comes from the front junction box need to be replaced or if they are tube metal and not of rubber construction, Part 22 looks to be hose which I'll replace with SS braid line..
    On this page http://tinyurl.com/3gm2xfc I'll be replacing #31 with stainless braid hose.
    I have no leaks anywhere.
    Do parts 20 & 23 customarily get replaced?
    Thanks
  • CatatonicBug
    • 6117
    • Clinton, UT
    You can buy a complete set of lines from Chacal on XJbikes.com (see link in my signature). However, I can tell you that the metal line is usually fine, as long as it is still in good condition. I left mine when I upgraded to SS lines.
    • my79is2bad
      • Apr 2011
      • 38
      • Salem, Oregon
      I'm having a set of braided S/S lines made locally and its a bit cheaper than anywhere else i've found. Once done will do a writeup on
      • KA1J
        • 664
        • Groton, CT
        Thanks for the replies,
        I'm still not sure if parts 20 & 23 as listed above are considered pipes or hoses. If they're hoses then they'll need to be replaced but if they're pipes, I'd rather leave them alone. #20 has what looks to be a spring around it...
        I just dunno...
        • CatatonicBug
          • 6117
          • Clinton, UT
          I just dunno...
          There is only one hard pipe. The rest are hoses. That one piece has a springy coil around it to protect it from getting scuffed by the forks. The replacement SS lines don't come with the coil because they are tougher and can handle the scuffing.
          • KA1J
            • 664
            • Groton, CT
            Thanks Bug, thats what I needed to find out. Good to know that's a hose under the coiled spring. I'll have to get that off as well then. Ugh... I was hoping that #20 was metal & something I could let slide.
            Bit by bit it's coming together. Sloooowly...
