Is there any problems outher than changeing the mounting bracket from the special headers to fit a standard ?
Special headers on a standard
1979 xs1100 f
142 main, 45 pilot, Jardeen crosover 4/2, no air box
floats @ 25.7
1979 xs1100 F
1978 gl 1000 goldwing
1981 gl 1100 goldwing
!986 venture royale 1300
Just an ol long haired country boy, come to town to spend some egg money
when ya get bucked off, get back onTags: None -
To fit the special exhaust to a standard frame, you have two choices (both hard). You can cut the mufflers loose from the collector, realign the muffler so it's straight then reweld, OR modify the standard frame to accept the special muffler/footpeg brackets. You'll also have to convert to the special rear brake pedal set-up (more welding). The brackets DO NOT interchange between frames, as the mounting holes are in different places, plus the special has the brake pedal pivot on the frame, not the bracket.
The first option will be the easier of the two....Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
Thanks Steve, There is a set on ebay, says kerker then he says they are bub headers, sent him an email asking what they came off of, he said a special, looks like they are going to go higher than what i want to pay any way, but the muffler clamps on to the colector, could be rotated to fit i would think then reweld the bracket maybe, oh well someone on here may want them.To fit the special exhaust to a standard frame, you have two choices (both hard). You can cut the mufflers loose from the collector, realign the muffler so it's straight then reweld, OR modify the standard frame to accept the special muffler/footpeg brackets. You'll also have to convert to the special rear brake pedal set-up (more welding). The brackets DO NOT interchange between frames, as the mounting holes are in different places, plus the special has the brake pedal pivot on the frame, not the bracket.
The first option will be the easier of the two....1979 xs1100 f
floats @ 25.7
1979 xs1100 F
when ya get bucked off, get back onComment
If you're talking aftermarket exhaust, that's a different kettle of fish...
Most (if not all) aftermarket exhaust will have enough 'adjustment' that you can fit them to either frame. As is typical of 'universal fit', they don't quite fit either really well..
bub headers
Yes after market Bub Headers 4/1 is what they are, look like a kerker with the cone baffel, they are bid up to 100 now but some one on here may need them but i have a fealing they are going to go high.1979 xs1100 f
floats @ 25.7
1979 xs1100 F
