Here goes...
Purchased my 78 XS11 in March of this year (2011). Ran OK but had some issues. Fixed the bad electrical gremlins and started working on the "too lean" condition at speed and the gaspy low end. Spark plugs were extremely lean.
Decided to re-jet due to the pods and 4 into 1 that a PO installed. I went up from 137.50 mains to 147.50. Still seemed weak all around so I bought some 152s for the mains. Still running lean on the top end. Low end was better though.
Pulled the diaphragms and found that the main needles were all set 1 notch LEAN. Made for a bi** to tune. Went BACK to the 147.50 jets. lol
I adjusted the floats that the PO adjusted from about 80MM down to 25MM from the gasket surface. Now the low end is terrible and a low end and very black plugs. Very very black plugs. Engine loads up and will die cruising at 30-40MPH.
Now what? I hate to adjust the floats to the rediculous height again but that seemed to run the best. The little "tang" was bent at least 45 degrees down.
Whats everyone running their floats at? Obviously 25MM on my 78 is waaaay too rich.
Ideas? Do the idle screws on the tops if the carbs make a difference on the low end rich at all? Or just idle speed?
Should I mess with the screws some more or pull the carbs and re-adjust the floats way leaner?
Should be able to get the pods to play nice.
