I Just Bought My Xs this past weekend and cleaned carbs got it running but the number 2 cylinder isnt firing. it is getting gas, fuel out the exhaust and coated plug, and i am also getting spark when i groung the plug to the engine. i am good with engines but cannot figure out what is going on. I am starting to think that the timing of the spark is off. all the other cylinders run fine but that one any suggestions on what it might be?? thanks in advance
Change the oil before you go running the engine if that is the case.
