Like a bad GF i cant get rid of
  • dezmitchell
    • Jun 2010
    • 51
    • vegrEVILle AB
    well bike was all fixed up and doing FINE but was out on the highway today when all of a sudden my tach kicked out ...Ok so i assume right away my charging system was acting up ....At this point im about 10miles away from home and its getting dark so eventually bike dies on the side of the road.
    Get it home on the back of the truck and the 3 bolts in my stator cover (that hold my field coil) are loose ...
    Pull everything appart stator seems fine physically but is only testing @ one ohm
    Field coil is all scuffed up and plain f**ked
    and the stator rotor has some scuffing in it.
    Also bike is on charger and i turn on key and NOTHING!! no lights not even a flicker .....is my battery that far gone. or am i lookin @ bigger problems
    Do you think my stator rotor can be used still if i clean it up with emmory cloth or something there is minor scuffung on the inside of it?
    1980 XS standard With Pods and Harley mufflers
  • SFSPECBIKER79
    • Jul 2008
    • 403
    • NC
    charge
    i'm not a wireing specialist by no means but i would check the regulator. i dont know how at the time but you can find it here on site. it my be fried. the stator is probbally ok if the windin is not broken or melted down any where. check the stator connection be hind the fusebox that has gave problems and has melted before. i think just the screws being loose would not cause any problem unless the stator did alot of moveing around damaged the coilings.
    79 xs 1100 spec & 80 xs 1100 g
    • dezmitchell
      • Jun 2010
      • 51
      • vegrEVILle AB
      The stator doesnt physically have damage but tests out side the perameters ....book says .4 and im testing 1 ohm.
      field coil and stator rotor are physically damaged ......not getting any reading on field coil and the stator rotor has some minor scuffing .....there wasdeffinatly parts rubbing.
      • SFSPECBIKER79
        • Jul 2008
        • 403
        • NC
        parts
        some time you can find these parts on ebay very reasonable. sounds as if you going to need them. i you cant find them there i have parts i may consider parting with if needed. good luck
        • dezmitchell
          • Jun 2010
          • 51
          • vegrEVILle AB
          Well i know i have good voltage on the batt i can get 13.28v out of it no problem to every fuse/ground on the bike. so it rules bad batt out .....its almost like i my ignition/key switch isint working.
          • James England
            • 3039
            • North of England
            Scuffing on the rotor won't be a problem, I'd say. Presumably there scoring isn't like 2mm deep or anything is it? Or heat damaged?
            IMO your stator is probably fine. I know the reading differs from the book but I don't trust the book figures 100%. I had a rectifier which showed up as defective and yet it worked fine. The main thing with the stator is that the coil has continuity. I would be tempted to use it and see.
            I suspect that the rectifier/regulator will be damaged though. The rectifier has several diodes and they all need to work. I'd put a Geezer replacement on if you need a new one. I did so and it's excellent. Worth the money. just for the extra charging, never mind the super-sleek build quality.
            Re the switch thing. You need to use a voltmeter and test the connections on the switch (and anywhere else that's suspect). The block connector on the right, behind the fuse board mount has connections from the alternator. I would look around there and check all the wiring loom for any signs of burning or heating up.
              DEz, have you checked for voltage on each side of the fuses? One could have blown but not look it. Does your starter try to trun if you short across the poles of the solenoid? Do you get an oil light or neutral light on?
              I think I will go out and check those bolts on my bike!!
              • dezmitchell
                • Jun 2010
                • 51
                • vegrEVILle AB
                I did try and see if i had voltage on any of my fuses and nothing ...the key is on and there is NO LIGHTS WHAT SO EVER ....but i have voltage right at my battery where do i start next ??
                so my starter doesnt do anything when i push the button ....Its like the battery isint even in the bike
                You know i was just starting to figure out why so many of you guys on here loved the xs11 FAST POWERFUL LOUD that instant arm strech feature when you drop a gear and hit the throttle to pass ...and she goes ahead and dies on me again lol FAIL!! If i cant get a yamaha to stay reliable how the hell am i ever guna ride a harley
                  • 3193
                  Like dgxser said does it do anything at all when you short across the two poles on the starter solenoid? Have you checked all the fuses including the one on the other side (main fuse) as not all the fuses are in that little panel. I would suggest rechecking all grounds as well. I have extra stators and rotors here if you need those, about three of each at last count...lol.
                  • dezmitchell
                    • Jun 2010
                    • 51
                    • vegrEVILle AB
                    AH you whore !!!!! i just got in from the garage and it was that main fuse ....put everything back together but im not charging ,......tach is on all lights working now so ....im thinking one of 3 things
                    1. Stator and/or field coil is fubar
                    2. I fried my rectifier
                    3. All of the above .....
                    I dont have my manual its in my truck and my truck is currently with my GF somewheres shopping for god knows how long ....so how do i test my rectifier?
                      • 3193
                      You could try the test on http://www.xs11.com/forum/showthread.php?t=67
                      Or you could download a manual from C-bug's page and read it from there. I am not an electrickery expert by any means. The Yamaha manual has a page and a half devoted to a regulator test so is too much typing involved and there is pictures too.
                        If your tach us working the the charging system is putting out, because the tach runs off the charging system pulses. Whether the charging is getting to your batter is a different story though. Check the big white plug behind the fuse panel, it is the wires from the charging system before it ties into everything else. That plug often melts.
                        • dezmitchell
                          • Jun 2010
                          • 51
                          • vegrEVILle AB
                          Well i put it all back together today just to see and sure as **** the bike runs and im getting charge to the batt.....around 12.48V on idle and 14v when i get around 3grand ......Rode bike around for a few hours and no problems so i pulled her into the garage polished it up and now were both happy
                            Glad to hear that!
                              Excellent!!
                              Glad it worked out!
