too much rear sag
    • 8077
    too much rear sag
    I have new 412 series shocks on my bike. The spring rate is 120/170. With no preload the sag is 50mm. I'm looking for 25- 30 mm. I didn't measure it with the preload cranked up, but I can't ride with a passenger. It's like driving an overloaded pickup truck. Next available rate is 140/200. I'm starting to think maybe progressive spring rates aren't such a good thing.
    Ideas?
    • 8931
    Put a spacer below the spring for more preload adjustment. You'll need a spring compressor though.
      • 8077
      It might take a short piece of big steel pipe! Where does one acquire a spring compressor for motorcycle shocks?
      I've considered using a floor jack, two hooks, and a length of chain. I'm just a little concerned about it taking my head off!
        • 2101
        I've used a ratchet strap to compress the springs on my shocks a few times.
        Just have to be a little creative on the hook-up so no metal from the ratchet scratches the spring or shock. HTH
          • 8931
          I make spacers out of PVC pipe, they hold up just fine.
          Shock with a PVC spacer...
          My home made spring compressor....
          • yamahansolo
            • Aug 2007
            • 1113
            • jawga
            His centerstand was mm's from the ground when was behind him. The dennis kirk mentioned spacees for the preload. They were 10 or 15 bucks I rhink? I will look wheni get baxk home tonight
            79 xs11 standard
            8mm msd wires
            tkat fork brace...
            Fox shocks...
            mikes650 front fender
            led's gallore...
            renthal bars
            gold valve emulators
            vmax tensioner
            Rifle fairing
            • yamahansolo
              • Aug 2007
              • 1113
              • jawga
              Marty in the catalog it has a luttle number two next to the xs11... reading number 2 in the fine print says requires 1/4" travel lumuters part number 58-0860 10.99 a pair ... and thus us for the 412
              79 xs11 standard
              8mm msd wires
              tkat fork brace...
              Fox shocks...
              led's gallore...
              renthal bars
              vmax tensioner
              Rifle fairing
              • yamahansolo
                • Aug 2007
                • 1113
                • jawga
                79 xs11 standard
                8mm msd wires
                tkat fork brace...
                Fox shocks...
                led's gallore...
                renthal bars
                vmax tensioner
                Rifle fairing
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  try yoga...
                  I hear its da bomb for saggy rear ends...
                  Here is the model number of my Heavy Duty shocks... 04-1455B/C
                  John
                  '81 XS1100H - "Enterprise"
                  • Elevener
                    • 608
                    • small town in TEXAS
                    I dont see why you need the spring compresser on these shocks. I do mine by hand.
                    Trapped in time. Surrounded by evil. Low on gas.
                    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                      • 8077
                      I don't see why you need the spring compressor on these shocks. I do mine by hand.
                      That's something I'd like to see!
