Clutch Ceased
  • mack
    • 2411
    • Ontario, Canada
    Annual event
    This happens every spring with mine. Starting the engine, pushing the bike, jumping on then kicking it into gear. Give it shot of throttle then slamming on the rear brake while pulling in the clutch lever. It's an annual event.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • davidsymons53
      • 197
      • Peterborough, Ontario
      Originally posted by old_chopper
      I would recommend instead of jamming it in gear while it's running to put the bike in 4th or 5th gear, engine off, pull the clutch in, then rock the bike forward a few times. It will pop the discs loose easier than 1st gear. Mine set for @15 years and was stuck solid. Fresh oil and filter, little rocking and it freed up just fine.
      Thanks. I like the idea of a gentle approach to start with.
      1981 XS1100 Special
      Previous Bikes
      1999 Honda Goldwing Aspencade 1500
      1983 Honda Goldwing Aspencade 1100
      1982 Honda CB900c
      1984 Honda vt750 Shadow. My son's bike now.
      1984 Honda vt500 Shadow
      • davidsymons53
        • 197
        Hey Mach. That sounds kind of scarey to me. I am not sure I have the coordination for "pushing the bike, jumping on". Maybe I can get some one to give me a push while I am on the bike.
        David
        1981 XS1100 Special
        Previous Bikes
        1982 Honda CB900c
          Hi David!
          I get the depression thing. I don't suffer from it, but I get it. My hat's off to you for being open about it. That takes guts. Have you got buddies there who can help with the bike when you're down? A good ride now and then is probably good for your brain.
          Best wishes!
          • mack
            • 2411
            • Ontario, Canada
            Old Age
            Ya, it's kind of my age gauge. When I'm too old or feeble to be able to push it hard enough or too decrepid to jump on, then I'm not healthy enough to be riding.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
