Yeah, that thing's horrible, isn't it? Whoever did that, did the same thing to the one on the final drive too. Thanks for the heads up on True Value. I haven'treally looked for new ones yet, but I'll check them out.
Further Adventures In The Carburetor Zone
Well, it wasn't the sync or the timing. So it must be my idle mixture, right?
So check my thinking on this: backfires are caused by the mixture being too rich, is that right? And turning the screws in leans it out, right? I have a ColorTune, but the color stays the same (whitish-blue) no matter where I have the screws set, so it's of no help.Last edited by Kit; 06-04-2011, 11:49 AM.XS1100SG - Obsession
Like I told my last wife, I says, "Honey, I never drive faster than I can see. Besides that, it's all in the reflexes."
-- Jack BurtonComment
Hey Kit,
I don't have any experience with the colortune device, can't recall what the colors indicate...blue or yellow for rich or lean, but if you're not able to see any color change, then it could be that you do have too rich OR too lean a pilot jet since you can't see a color change. Could also be that your pilot screw tips are broken off in the carbs?
Backfiring can also be poor/intermittent ignition, not firing on normal sstroke cycle, fuel builds up in exhaust, then wasted spark hits during exhaust cycle and lights fuel in pipe via open exhaust valve and spark plug firing.
Hopefully others with Colortune experience will chime in with more precise tuning/adjustment advice.
T.C.T. C. Gresham
__________________
Did you replace the teeny-tiny O-rings under idle-mix screws and make sure the teeny-tiny washers are in place and located between spring and O-ring? When replaced and sealing properly you should be able to kill motor when turning screw all the way in. Each screw SHOULD cause the SAME reaction from motor if all is sealing good.......JAT81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
__________________
Did you replace the teeny-tiny O-rings under idle-mix screws and make sure the teeny-tiny washers are in place and located between spring and O-ring? When replaced and sealing properly you should be able to kill motor when turning screw all the way in. Each screw SHOULD cause the SAME reaction from motor if all is sealing good.......JATCy
Did you replace the teeny-tiny O-rings under idle-mix screws and make sure the teeny-tiny washers are in place and located between spring and O-ring? When replaced and sealing properly you should be able to kill motor when turning screw all the way in. Each screw SHOULD cause the SAME reaction from motor if all is sealing good.......JATXS1100SG - Obsession
Well, I'm cautiously optimistic. After another 110 miles, everything seems to be squared away.
I replaced the 42.5 pilot jets with 45s. When tuning, I discovered that when the mixture screws were turned all the way in, the motor wasn't quitting. Last time I tuned, all four would kill it when turned all the way in. So I pulled the screws and discovered that for some reason I had put the washer between the screw and the spring, instead of between the spring and the o-ring (as noted above when I responded to motoman, I could have sworn I installed them in the correct order...dunno what I was thinking, but good call on that). As a result, the end of the coil on the springs had cut into the o-rings and severed them. All four of them. I read somewhere that Harbor Freight sells a kit of 225 o-rings of various sizes for $6.99, and there are 10 of the correct size in that kit. Replaced those. Somewhere during all this, I noticed that the seal for the gas cap vent was literally falling apart, so I replaced that. Found a thread discussing that, and someone had discovered that a thermostat gasket from a Toyota Camry works, so that's what I got. And lastly, even though I'm not superstitious, I decided to do something about the gremlin bell that the PO had left on the bike when I bought it. It was dull, a little rusty, and hanging way too high (up high on the forks in front of the horns). So I polished it up a bit, then hung it down low on the frame. Can't say if it did any good or not, but I figured it couldn't hurt.
I've taken her out on two short trips now, and I have power through all ranges again, with no sputtering, backfiring, or bogging down. Keeping my fingers crossed, but I think I can finally close this particular chapter.XS1100SG - Obsession
