Octopus on an XJ?
  • Filter
  • Octopus on an XJ?
    Got the carbs from a friend's XJ to repair and noticed that they have an octopus attached. I thought that they only came on the XS 1100 Specials.
  • #2
    The XJ is 'sort of' an '82 Special in that it was based more on the 81 Special than on the 81 Standard.
    • #3
      XJ has the 'octopus' as standard equipment. Hose routing is the same as the Special; stock XJ seat has a diagram on the bottom of the pan showing the hose path. Petcocks are the same as the Special, 4 positions, Off, Prime, On, and Reserve.
      Note the XJ carbs are slightly different than the XS...54mm bells vs 52 and stock jetting is leaner. XJ carbs have a cable operated choke; linkage is a bit different than the XS. Otherwise the XJ carbs are the same as the 'late' model '80 - '81 carbs.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
