1980 XS1100 Balance Point?
  • Craigaboy
    • May 2011
    • 38
    • Anchorage, ALASKA
    I am building a quick insert for my motorcycle jack that will pick up a couple frame members and allow me to access to everything (oil filer, exhaust, etc.)
    Anyone know the balance point on these bikes? I thought I would throw it out there if someone can save me some time...
    1980 XS1100 Midnight Special
    1980 XS400 Special - (cafe project)
    2009 Polaris 600 RMK (got to ride something in the winter)
    Hi Craig,
    it's gotta be a little ahead of the centerstand pivots.
    Exactly where depends on all manner of variables, small things like how full is the gas tank and how worn are the tires to big things like does the bike have a windshield or a fairing or hard bags etc. etc.
    The only way to find out is by experiment.
    • Craigaboy
      • May 2011
      • 38
      • Anchorage, ALASKA
      Hi Craig,
      10-4 ... It will be easy to build it - lift the bike up - slide it fore/aft to find a good center point - and then drill the location/retainer pins. I will throw up some measurements and photos this afternoon. Thanks!
        You want to drill holes in the bike frame?
        BAD BAD IDEA!
        • Irukandji
          • Apr 2011
          • 75
          Holes in the Jack mount nate.
          • Craigaboy
            • May 2011
            • 38
            • Anchorage, ALASKA
            Yep, almost finished. Will throw some photos up.
            • Craigaboy
              • May 2011
              • 38
              • Anchorage, ALASKA
              Here are a few picts. Will be bolting jack adapter to jack lift and securing the bike with additional methods.
                Nice! Make it foldable, and you might have a marketable tool there!
                • Joab
                  • Aug 2010
                  • 472
                  • Ozark, Alabama
                  Hell, foldable or not, Id buy one from you! Beautiful bike btw!
                  Joab
                  "If nothing else, it will be interesting..."
                  ______________________________________________
                  1979 XS1100SF
                  1972 XS2 650
                  Ozark, Alabama
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    moving target
                    Remember the point moves as you remove things like wheels, exhaust, etc.
                    Just be sure not to only rely on the jack but use stands also.
                    John
                    '81 XS1100H - "Enterprise"
                    • Craigaboy
                      • May 2011
                      • 38
                      • Anchorage, ALASKA
                      Thanks man. I love the look of an original machine that has been taken care of so well. The little bumps, nicks, and worn areas add to the character. - I'll throw up a few dimensions when I have it finished in case someone wants to do something similar.
                      John
                      Will do - I'll be fabricating some additional supports before doing any work on the bike while elevated.
                      • tantor
                        • Aug 2010
                        • 43
                        • North Vancouver B.C.
                        I like that bike caddy. I've already burnt 3 pads off of my jack, due to hot exhaust. Try lining the lift point with an old inner tube, to protect your paint.
                        1982 XJ1100
                        • jwhughes3
                          • 2798
                          • Home of the Alamo
                          leather
                          i am thinking leather instead of rubber. more heat resistant. tough. easy on paint and plentiful.
                          john
                          • Craigaboy
                            • May 2011
                            • 38
                            • Anchorage, ALASKA
                            good thought. either one would work. i have some old welding gloves - i'll cut up the area that runs up your arm and super 77 it to the tubing halves. for now the inside of the tubing is polished and the edges are smooth and round.
                            • tantor
                              • Aug 2010
                              • 43
                              I only said that because I'm economical, and I know that I keep used inner tubes for purposes just like this!
                              1982 XJ1100
