I tore it all down yesterday and got all the way down to the clutch basket, but I cound not stop the clutch from spinning. I could not get the center nut off because it kept spinning. Is there an easy way to stop this, and where can I pick up a gasket for the clutch cover? Any info would be helpfull at this point. Thanks, Silvtgr38
changing clutch on a 1982 xj1100
Easy way to stop the clutch turning is with the rear brake. I tend to kneel on the brake pedal while I turn the bolt.
As to the gasket, you can cut one form gasket material, or most folks tend to use RTV "form-a-gasket" or some other called "The Right Stuff".Life is what happens while your planning everything else!
78 XS750 -
Impact wrench takes it off as well if you have one.Nathan
Theodore RooseveltComment
I wedged a 2x4 in the rear wheel and tapped my wrench handle with a hammer. If you do this, dont go crazy wacking the wrench. I tapped until I saw the handles position change enough to indicate it was free for just the wrench. Im sure noone will recommend this. Especially with tools that are nice.79 Special
2012 FJR1300
78 E (project. Clutch problems from PO) Must sellComment
