Had a slow leak on the front tire, used the soap and water trick to find out that air is leaking around the threads of the valve stem. Any trick or tips on how I should seal it up? Can I just remove the one nut from the outside put something on it to stop it from leaking? Looks like its just leaking by the threads, not at the base or anything...
Leaky valve stem
Leaky valve stem
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Tags: None -
Tighten up the nut see if it stops leaking.............replace valve stem, and could do it without removing wheel or removing tire.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
