I have had a problem with #1 cylinder running cold at idle(i can grab the pipe)Even after a ride it is running about 100 degree's cooler than the others..
Here is a pic of the plugs pulled from it. they have about 200 km on them. I replaced them yesterday.How do you think the carbs need to be adjusted.I'd like to get it running right
I also noticed when riding at a constant speed that the tach will fluctuate about 3-400 rpm. Any help is appreciated.
1-4 left to right
1 and 2
3 and 4
1-4 left to right
1 and 2
3 and 4
After cleaning and polishing it looks like the leaky float has different solder than the rest of the floats so someone did a bad repair job or used the wrong solder but it's easy enough to fix.
